Arbiter - Treble Bass Fuzz Face  [schematic]
Re: Arbiter - Treble/Bass Boost
Postby sinner » 07 Apr 2012, 07:17
peps1 wrote:Used the issue 1 fuzz face screw holes as a scale reference, as I assume it the same enclosure.
71mm x 43mm
What's the distance between screw holes in FF?
Has thanked: 1240 times
Have thanks: 1099 times
Re: 1966 Arbiter Treble Bass Fuzz Face
Postby Chugs » 07 Apr 2012, 09:40
I have a couple of Fuzz face enclosures and the distance between the centres of screw holes is 51mm.
For this message the author Chugs has received thanks:
sinner (07 Apr 2012, 09:42)
Chugs
Has thanked: 59 times
Have thanks: 48 times
Re: arbiter trebel bass boost
Postby rustyg » 08 Apr 2012, 06:17
Thanlks but been there, done that...
I have this beast so I don't need the schematic or values; I can just look at my board.
It's the OFF BOARD wiring I'm interested in. I've done a fairly thorough web search & have come up dry. Any one have any other resources to the OFF BOARD WIRING? from the pictures on the web, it looks typically 'British'.
rustyg
Postby phatt » 08 Apr 2012, 13:48
Never seen one in the flesh but I was under the understanding that these unit where *positive ground*?? If so the then the pictures make sense as the red positive goes to ground.
Check the electros for clues as they will also be polar reversed.
Phil.
phatt
Have thanks: 264 times
Postby sinner » 08 Apr 2012, 16:38
phatt wrote:Never seen one in the flesh but I was under the understanding that these unit where *positive ground*?? If so the then the pictures make sense as the red positive goes to ground.
Phil.
Yeah, that sets me off. I did the wiring layout but stopped at battery connection. The schemo I have is for BC109, all we know thats NPN trannies....
Postby phibes » 08 Apr 2012, 18:46
What's confusing about the off-board wiring? It should be pretty straight forward to figure out from the schematic regardless if it's it neg or pos ground.
Image Ken
phibes
Has thanked: 85 times
Have thanks: 185 times
Postby sinner » 08 Apr 2012, 18:48
phibes wrote:What's confusing about the off-board wiring? It should be pretty straight forward to figure out from the schematic regardless if it's it neg or pos ground.
Not quite. Schemo screams for NPN silicons, and wiring picts shows positive (red wire) going to ground.
Postby phibes » 09 Apr 2012, 06:41
Ah I see. Well all wire coloring in the OP unit match all the old photos I got of other units so the off board wiring looks right. Two red wires look replaced but they we're hooked back up right, same with color. I never really looked closely at this one but yeah, the jacks are grounding to positive and the battery is being disconnected from the circuit off the positive wire so good catch there! I'm surprised that wasn't noted in the schematic in the other thread.......
Does the unit work?
Image Ken
phibes
Postby sinner » 09 Apr 2012, 12:03
Want some more confusion?
E-caps on the same picts I was referring to are pointed negative to ground!
I say WTF?
Postby lolbou » 09 Apr 2012, 14:19
Topics merged.
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
For this message the author lolbou has received thanks:
sinner (09 Apr 2012, 21:01)
lolbou
Has thanked: 347 times
Have thanks: 240 times
Postby DrNomis » 09 Apr 2012, 16:09
Just wondering if anyone's finished building one of these and if so, how much bass/treble boost do you get with it?..... :hmmm:
Has thanked: 123 times
Have thanks: 397 times
Postby phibes » 09 Apr 2012, 16:55
sinner wrote:Want some more confusion?
I say WTF?
Yeah I can see the confusion now after eyeballing it. It looks wired for positive ground. It'll work either way as the electros are facing where they gotta go. I wonder why they did it that way? Did they do the same on the silicon Fuzz Faces?
Image Ken
phibes
Postby Electric Warrior » 09 Apr 2012, 20:52
No, they're usually wired up correctly.
Electric Warrior
Has thanked: 20 times
Have thanks: 83 times
Postby gigelmargel » 07 Feb 2013, 07:23
Hello all,
I want to build an Arbiter Bass/Treble Face, but I didn't find a layout of the parts. I've tried to retrace it using the photos from this topic, but I don't have enough skills to do that.
Can anyone help me?
Best regards,
Radu
gigelmargel
Has thanked: 16 times
Have thanks: 15 times
Postby LucifersTrip » 10 Feb 2013, 08:58
shouldn't the schematic be cool enough?
viewtopic.php?f=19&t=10359#p109284
LucifersTrip
Has thanked: 21 times
Have thanks: 85 times
Postby gigelmargel » 10 Feb 2013, 09:01
LucifersTrip wrote:shouldn't the schematic be cool enough?
http://freestompboxes.org/viewtopic.php ... 59#p109284
Thank you LucifersTrip!
I've seen the schematic, but in the photos I saw some capacitors that I couldn't identify. I will try again, using both the schematic and the photos.
Best regards!
gigelmargel
Postby LucifersTrip » 11 Feb 2013, 21:09
Cool...if you find something different, let us know
LucifersTrip
Re: Arbiter - Treble Bass Fuzz Face
Postby The Rotagilla » 17 Oct 2017, 15:51
If anyone saved the schematic could they re-post it? Thanks.
The Rotagilla
Have thanks: 57 times
Postby bluesbreaker62 » 21 Oct 2017, 15:47
Here you go :thumbsup
For this message the author bluesbreaker62 has received thanks:
FuzzMonkey (21 Oct 2017, 21:52)
bluesbreaker62
Have thanks: 26 times
Postby roseblood11 » 21 Oct 2017, 19:50
roseblood11
Has thanked: 348 times
Have thanks: 310 times
