Tycobrahe - Parapedal  [schematic]
Postby analogguru » 10 Jul 2007, 19:24
And here is the Tycobrahe Parapedal:
http://wc6w.50webs.com/wc6wvint/fr412.html
Have thanks: 116 times
Postby modman » 04 Sep 2007, 01:22
geofex.com posted a project on this last summer:
8/25/06 Updated - the Tychobrahe Parapedal schematic and layout. The board bolts into a Crybaby shell and clones the Parapedal. Fixed a capacitor bug and added a new negative ground version.
Has thanked: 3110 times
Have thanks: 559 times
Postby analogguru » 04 Sep 2007, 02:33
....last summer
8/25/06 Updated .....
:?: I think this should be read as last year´s summer... :wink:
Postby soulsonic » 04 Sep 2007, 09:19
I heard a clip of the Chicago Iron remake of the Parapedal. It sounded interesting, but more of a special effect than a normal wah.
Has thanked: 56 times
Have thanks: 274 times
Postby modman » 04 Sep 2007, 10:59
analogguru wrote:
....last summer
Read what you like, but I think you mean "should be written" :wink:
I Still Remember What You Did Last Year's Summer :?
Zat iz doch gar no Ingrish!
The effect will work just fine any summer, there is no GE in there!
Postby Vinnie » 26 Sep 2007, 15:51
What type of effect is in fact?
Thanks in advance.
Vinnie
Postby dajm » 26 Sep 2007, 16:50
it's a wah pedal, Tony Iommi uses one
http://filters.muziq.be/model/tycobrahe/parapedal
dajm
Postby Kaos » 26 Sep 2007, 17:15
any soundsamples around?
The camel is a horse designed by a committee that never met.
Kaos
Postby Vinnie » 26 Sep 2007, 17:15
Thanks dajm!
Vinnie
Postby dajm » 26 Sep 2007, 20:27
there are some sound clips here of a reissue made by Chicago Iron (they've released reissues of the Tycobrahe pedals - Parapedal, Octavia + Pedal Flanger)
They'll give you some idea of the sounds it can make....
http://www.chicagoiron.com/parachute.html
Thanks dajm!
glad to help !
dajm
Postby alteredsounds » 01 Oct 2007, 14:32
hey everyone, just joined, recognise a few names. Here's a few pretty close up pics and a few part names of my original for anyone wanting to build this. I'm now in a better position to clarify most part values if anyone is interested.
http://www.alteredsounds.com/modules.ph ... age&pid=22
alteredsounds
Have thanks: 6 times
Postby Vinnie » 03 Oct 2007, 13:08
Which pot of the comercial ones to use that fits a "dunlop" shell?
Vinnie
Postby modman » 24 Jan 2008, 18:27
alteredsounds wrote:Along the same line, I remembered I still have some gut shots of my Tycobrahe Parapedal online if anyone's interested. I intend at some point to clone this, if i ever get time!
http://www.alteredsounds.com/tyco/t1.jpg
http://www.alteredsounds.com/tyco/t2.jpg
http://www.alteredsounds.com/tyco/t3.jpg
http://www.alteredsounds.com/tyco/t4.jpg
http://www.alteredsounds.com/tyco/t5.jpg
http://www.alteredsounds.com/tyco/t6.jpg
http://www.alteredsounds.com/tyco/t7.jpg
Re: Tycobrahe - Parapedal
Postby McHaven » 04 Feb 2009, 09:12
I'm looking at putting together one of these, but I'm curious whether or not the GGG modifiable Wah PCB could work. I'm a total newbie at this, and really don't want to have to make my own PCB. Anyone know?
McHaven
Postby soulsonic » 04 Feb 2009, 09:36
McHaven wrote:I'm looking at putting together one of these, but I'm curious whether or not the GGG modifiable Wah PCB could work. I'm a total newbie at this, and really don't want to have to make my own PCB. Anyone know?
The Parapedal is a totally different kind of circuit than the usual wah. You would need a board designed just for it.
R.G. Keen has a Parapedal project up at Geofex.com
Here is a link to one of the layouts: http://www.geofex.com/FX_images/parapedal_layout.gif
Here is the updated schematic:
Postby McHaven » 04 Feb 2009, 17:34
Here is the updated schematic: http://www.geofex.com/FX_images/parapedal.gif
Right, I have that schem/layout, but I was just curious of the best method to use to get my PCB. Looks like I'll have to make one myself? Or can I order one online from the layout?
McHaven
Postby Solidhex » 09 Feb 2009, 09:52
Yo
I built a clone of the Parapedal. I was lucky enough to find a 100k dual pot with a long shaft. I was able to a/b it with the Chicago iron version and I'd say they sounded very close. Its almost too over the top for regular use. There's this huge low end "thunk" when it gets into the bass range. If you like having a some fun pedals around for recording I recommend it.
If you plan on making a clone don't buy one of the replacement pots from Chicago Iron. They're really nice guys but they'll just send you a regular panel mount alpha dual pot with no pinion, gear, or mounting hardware and they'll charge you $15...
Iommi used the Parapedal from around Sabbath Bloody Sabbath on I've heard. For his more iconic wah tones he used a Colorsound.
--Brad
Solidhex
Has thanked: 10 times
Have thanks: 17 times
Postby joegore » 09 Feb 2009, 14:33
No doubt true — not that I could fully understand the schematic in any case. But what I HEAR in the audio demos is simply a sweepable bandpass filter with a much lower cutoff point than a conventional wah — somewhere around 100 Hz, right?
So would it not be possible to get an identical effect, if not an identical circuit, using a standard wah layout and tweaking the filter ranges? That's assuming you WANTED this sound, which isn't necessarily a given.
joegore
Have thanks: 8 times
Postby Solidhex » 05 Mar 2009, 12:10
Yo
I haven't heard any regular wah circuit come close to the Parapedal circuit. I could be wrong in describing it but it seems to ( to my ears ) have a narrow q that is also very extreme. The resonance is crazy and it seems to do the huge synthy woosh sound at the heel position. I don't think sonically it can be approximated with the garden variety inductor equipped wah circuit.
I'd recommend building it if you like to have a lot of unique circuits around. The problem generally is finding a dual pot. I need to bust out the breadboard so I could test out a standard 100k pot controlling a dual vactrol that is in turn controlling dual voltage dividers instead of the usual dual pot setup.
--Brad
Solidhex
Postby Visualdistortion » 27 Apr 2010, 08:33
Anyone save them? the links seems to be dead!
I wanna make it
I wanna make it wit chu
(again and again and again)
French... sorry ;)
Visualdistortion
Next
Users browsing this forum: Big_Mike, goostah and 6 guests
