Ibanez - FP-777 Flying Pan
agoldoor
Has thanked: 39 times
Been thanked: 21 times
Post by agoldoor »
Hey, yo, sinnerooskie!
BYOC just released a Flying Pann kit that I am pretty sure is based on the original. I don't know if there's much you can derive from the following, but this is a link to the kit instructions:
http://buildyourownclone.com/soaringski ... ctions.pdf
Has a couple clear shots of the traces and all the component values... so that's something, I guess, heh.
Been thanked: 909 times
Yeah, I have it already, but I'm more after the vintage board shots, I'm going to do the repro layout
Professor SourTone
Been thanked: 58 times
Post by Professor SourTone »
Unfortunately the cap on the trace side is very fixed and I'm unwilling to disturb it...
Sir? You're uber awesome!!!
Has thanked: 232 times
Been thanked: 887 times
sinner wrote:Sir? You're uber awesome!!!
Let me second that !!
What's the PCB dimension if I may ask?
Also, could you do another PCB shot? More "stright" and "in the face" ;)
Güero 2.0
Been thanked: 24 times
Post by Güero 2.0 »
Sweet!
Could you pelase, measure the trimpots? voltages or reisitance.
Tks!
I see three 100k trimmers. Why measure?
sinner wrote:What's the PCB dimension if I may ask?
You don't like the use of too much perspective correction either I presume :wink:
borislavgajic
Has thanked: 131 times
Been thanked: 277 times
Post by borislavgajic »
:thumbsup this is vintage enough for me :applause:
Naaah, it's for professional circuit developers ;)
Güero 2.0
Post by Güero 2.0 »
Dirk_Hendrik wrote:I see three 100k trimmers. Why measure?
Bias?
And why is that bias provided with a trimmer?
Güero 2.0
Post by Güero 2.0 »
You are a respected member of this forum and also the DIY world.
For this reason, respect should be mutual, I guess.
Please, don't play the stupid.
You know what I mean, when I kindly asked for trimpots adjustments.
If our colleague can read these adjustments would be fine.
Bernardduur
Has thanked: 94 times
Been thanked: 732 times
Post by Bernardduur »
Readable schematic
I also added the resdef; got one nice old one in a trade. Sounds absolutely wonderfull!
The switch is different to what was on the factory schematic. It is a 6P5T switch that has 3 pre arranged settings; the 2 in between settings are used to gound both outputs so you don't hear the switch clicking.
armdnrdy1
Has thanked: 10 times
Been thanked: 67 times
Post by armdnrdy1 »
Thanks for that Bernardduur!
I recently checked the factory schematic against available board shots.
Are you sure that the (red-trace side) 470K between C27 & R21 goes to Vref2?
I see the Vref2 trace running under the 470K, and the 470K connected to the ground side of uninstalled R20.
Also…good catch on the switch!
Couldn’t the same thing be achieved using a 4 pole, 3 position rotary switch and installing a 1M resistor to ground on each output?
