Ibanez - CP-830 ( Compressor )  [schematic]
Postby analogguru » 24 Feb 2008, 13:50
Here is your chance for guts of the CP-830:
http://www.megameier01.homepage.t-online.de/eyComp.jpg
very intersting:
three transistors, one 741 and a LDR-optocoupler...
reminds me a little bit to the Dod 280....
you can buy it here for further investigation:
http://cgi.ebay.at/Ibanez-Compressor-pr ... dZViewItem
Have thanks: 116 times
Re: Ibanez - CP-830 ( Compressor )
Postby modman » 29 Feb 2008, 22:22
First link is already down, missed my chance...
Did anybody save it?
Has thanked: 3110 times
Have thanks: 559 times
Postby analogguru » 29 Feb 2008, 22:35
modman wrote:First link is already down, missed my chance...
Do you mean something looking like this:
Postby Kinki fuzz » 13 Aug 2008, 12:40
I've got one of these, I wrote the schematic out of it, got it somewhere, maybe I can scan it (handwriten...) or something to post it here. Will try. Pretty similar to DOD280...
The issue is it doesn't work, (bought it realy cheap because it was faulty, I thougth that just the box was worth the price), it sounds, but doesn't compress and does nothing. After much fooling around with it, I discovered the problem was the optocoupler, but it has nothing I can understand writen so I can find a replacement. Tried a couple optocoupler but did not work fine (distorted), I guess changing optocoupler you also need to change some resistor or so, but well, if I'm gonna change the circuit that much, Id better mount my dinacomp clone inside, which was my intention when I bought it. Anybody has a clue about what kind of optocoupler did maxon use or whatever?.
Kinki fuzz
Has thanked: 18 times
Have thanks: 2 times
Postby borislavgajic » 13 Aug 2008, 22:08
You could try LED/LDR.........and see what hapens
borislavgajic
Has thanked: 140 times
Have thanks: 249 times
Postby Kinki fuzz » 14 Aug 2008, 07:04
I already tried the led/LDR option and it was the same as with the optocoupler, which in the end are led + ldr in a case, if I'm right (?). Tried different led colors, different position/angles, even changed some resistor to vary the light intensity. I don't remenber the details, cos it was like 1 or 2 years ago. In the end, I think the circuit is tuned for a given LDR/led conbination, with its given sensitivity, and so on, and this is critical for the correct function.
I will post schematic and maybe some photo, although the pcb it is pretty fucked up, since I fooled around a bit soldering and dissoldering components and so on.
Kinki fuzz
Postby borislavgajic » 14 Aug 2008, 18:50
post all you have......close up pictures...both sides of pcb......schem
..I guarantee there is somebody here that can help :thumbsup
borislavgajic
Postby pedalgrinder » 02 Jan 2012, 15:30
this is a great compressor i think mictester made his own version of it somewhere
pedalgrinder
Has thanked: 202 times
Have thanks: 151 times
Postby mictester » 02 Jan 2012, 15:54
pedalgrinder wrote:this is a great compressor i think mictester made his own version of it somewhere
Mine was based on a Maxon board that wasn't ever released. Maxon had problems procuring the specified optocoupler, so abandoned the design.
I liked the way the rectifier transistors provided the current for the LED part of the opto - it was an elegant solution. I modified it so that it would work with the RPY58A LDR (nothing special - I just had a lot of them!) and a green LED. The amount of compression available without distortion was quite amazing, but there was one minor design issue - it was possible to start to clip the signal (audibly) if you took the output from the emitter of the phase splitter transistor, as originally designed. The ones I built took the output from the output of the op-amp and through an emitter-follower buffer transistor. That eliminated the distortion altogether.
The other issue was that it was sensitive to supply voltage - the amount of compression available reduced as the battery discharged!
mictester
Has thanked: 32 times
Have thanks: 795 times
Postby pedalgrinder » 02 Jan 2012, 16:08
yeah fair enough i just knew you'd done something somewhere thanks for verifying. :thumbsup
pedalgrinder
Postby Keijo » 17 Sep 2014, 19:17
Hello all, my first post here!
I have the Ibanez CP-830 and its broken. When its off guitar signal goes through like it should, but when its on signal sounds like farting.
Does anyone have any idea what could be the problem?
I measured about 9 volts from op-amp pin 7 and about 5 volts at pins 3 and 6 so they should be alright. I also tested the transistors be-junction with DMMs diode-tester and it showed about 0,7 volts and the led of the optocoupler showed about 1,4 so they should be alright.
Keijo
Re: Ibanez - CP-830 ( Compressor )  [schematic]
Postby Keijo » 17 Sep 2014, 19:42
Forgot the schematic, so here it is.
Keijo
Postby mirosol » 17 Sep 2014, 20:51
Moikka Keijo! Tervetuloa.
Have you tried probing it to see where the signal dies? http://www.diystompboxes.com/pedals/debug.html
+m
mirosol
Has thanked: 156 times
Have thanks: 359 times
Postby Dirk_Hendrik » 17 Sep 2014, 20:53
Voltages on CP2 and 6 please.
After that,
Start with the electrolits. They're the most common cause of failure.
Has thanked: 253 times
Have thanks: 1014 times
Postby Keijo » 18 Sep 2014, 07:54
Dirk_Hendrik wrote:Voltages on CP2 and 6 please.
After that,
CP2 voltage is about the same that pin 3 is (as it should be, right?). All transistors collectors have a little under 8 volts so they should be alright too.
I sent 1kHz signal from signal-generator and measured with oscilloscope and it showed things like this. :) Yellow is signal in and blue is signal out.
Keijo
Postby gigelmargel » 18 Sep 2014, 19:44
Anyone has a veroboard layout for it? I searched, but I didn't find any...
Thank you!
gigelmargel
Has thanked: 16 times
Have thanks: 15 times
Postby Keijo » 19 Sep 2014, 09:36
Ok, changed the electrolytics and the op-amp. It works now. :)
Keijo
Ibanez - CP-830 Compressor 1979
Postby modman » 24 Dec 2017, 21:00
IBANEZ CP-830 COMPRESSOR Original "R" Serie 1979 Made In Japan
http://www.hendrixguitars.com/Ef248.htm
Users browsing this forum: No registered users and 6 guests
