Heathkit TA 28 Fuzz Booster
- pinkjimiphoton
- my favorite amplifier: my own, a redesigned princeton
- Completed builds: so fucking many goddamn pedals it would make your ass hurt just looking at 'em all!!!!!
there's videos that totally suck of about 90 of 'em here:
http://youtube.com/666pinkster
gimme a like: http://facebook.com/pinkjimiphotonrocks - Location: new world order land (formerly la-la land)
- Has thanked: 358 times
- Been thanked: 479 times
- Contact:
hi guys,
was surfing around evilbay earlier, and spotted this:
https://www.ebay.com/itm/150894762099?s ... 1423.l2648
they were kind enough to provide this:
and a gutshot!
and even a schematic, too:
so i looked up the transistors, to see what would sub, and it came up mpsa18 for q1, and our old friend 2n3906 for q2. i decided to suggest germanium there, but pretty much anything should do i would imagine.
that said, i was bored, so i worked up a vero...
gonna build it at some point just for sh*ts and grins...
just thought i'd share...was mighty nice of them to provide enough info to not need to build the pedal.
if anyone whacks it together, please let me know!
happy fumes!
and a gutshot!
happy fumes!
Slava Ukraini!
Slava Ukraini!
- LucifersTrip
- my favorite amplifier: Companion Psychedelic Machine
- Completed builds: Mosrite Fuzzrite (Si), Mosrite Fuzzrite (Ge)[2], Get Lo-Fi Fuzz, Fuzz Face (Ge) [2], Fuzz Face (Si) [3], Mos-Face, Vox Tone Bender, Kay Tremolo, Os Mutantes Fuzz [2], Psychedelic Fuzz, Smokey Amp, Sunn Buzz, Jen Fuzz, Fancy Fuzzbox, Muff Fuzz (op amp) [2], Buzz Box, Fuzz King, Rangemaster [5], Maestro FZ - 2/3, Ruby Amp, Orpheum Fuzz (Ge) [4], Great Destroyer, Schizo, Carlsbro Suzz, Shin-Ei Companion Fuzz (si), DOD 250 Gray [2], Super Dirt Fuzz, Fuzz Factory, Jordan Boss Tone, Sam Ash Fuzzz Boxx, Heathkit TA-28 Fuzz, Olson New Sound Fuzz, LRE Fuzz Sound, Green Ringer, Vox Super Beatle (Ge), Colorsound One Knob (Ge), Demon Buzzz [2], Demon Wasp v1, Demon Wasp v2, Super Hard-On, Bazz Fuss, Burns Buzzaround [2], Selmer Buzztone, Shin-Ei Companion Fuzz (Ge), Fuzz Face/FY-2 (Ge), Zonk Machine, Univox Squarewave, Demon Fuzzz, Mosrite Fuzzrite BG-500/1000 (Ge), Univox Superfuzz, Marshall Supa Fuzz, Demon Monster, AA Overdrive/ Retro Fuzz, Tone Bender MKII, Psychtar, Jordan Vica Vibe, etc...
- Has thanked: 19 times
- Been thanked: 71 times
- Contact:
here's my reply from the other forum just in case...
cool to see you're still looking out for the odd fuzzes.
I built that one a while ago from the same schematic:
http://www.muzique.com/schem/heathkit.gif
To my ears, it is most similar in sound to the Sam Ash Fuzzz Boxx/ Astrotone...but better. It's one of the few 1.5V fuzzes that are silicon. Still my favorite is the Sun Buzz...
You know how it is with cross references...they're many times ridiculous. Coincidentally, I did use a 2N3906 for Q2 with a gain of around 200 - 250. Note that my vintage ones are in the 100 - 150 hfe range. I have no idea why you're thinking about a germanium there. I doubt it'll bias well.
according to the analogguru schematic, Q2 would be cool with BC309B, which has min hfe 250.
http://analogguru.an.ohost.de/193/schem ... _TA-28.gif
I did try many different Q2's before deciding on the 2N3906.
I also used a switch between the original input cap and a .033uF which smoothens out some of the raspiness when the drive (50K) is higher up.
Anyway, here's my final version with voltages & notes.
hey jimi!hi guys,
was surfing around evilbay earlier, and spotted this...
I actually had some vintage 2N3391's laying around, which had hfe's ~ 350 -400. The MPSA18 is way higher, 800+.so i looked up the transistors, to see what would sub, and it came up mpsa18 for q1, and our old friend 2n3906 for q2. i decided to suggest germanium there, but pretty much anything should do i would imagine.
There are a couple things that are unusual about that pedal...It uses an NPN / PNP combo and it's a 1.5V silicon...so it'd be sacrilege to change to 9V...the 1.5V is part of the fun! just kidding...you should always try everything.
yah, you know i'm gonna try it with a 9volt.
When tweaking, I noticed it was not loud enough and there was a simple fix. Just lower or remove the 10K before the tone control. I actually wound up putting a 10K pot there.from owner of original:
As for how the example I have sounds, it's a sort of fuzzy overdrive, but there is a volume cut with it engaged. It needs another amplifier stage at the end.
- pinkjimiphoton
- Contact:
yah, i could have made it smaller, but at 10x10, it's pretty small already.roseblood11 wrote:R8 and C3 could join at line f if you add a cut at f8 and
R3, R5 and +1.5V could join at line c.
You could omit lines a nad b and jumper...
i am beginning to not like standy-uppy resistors...too easy to break all too often.
thanks tho!
Slava Ukraini!
Slava Ukraini!
- kaycee
This is a really nice fuzz, one of my favourites actually. I build mine as per the schematic and don't seem to have volume issues. I don't use specific transistors in mine, just sort through and tune to ear, the tone control although crude works quite well. Don't be put off by the 1.5volt operation, it has plenty of output. Its a bit like the Jordan Bosstone which also use a NPN/PNP combi.
- pinkjimiphoton
- Contact:
cool! i may give it a go in a couple days
Slava Ukraini!
Slava Ukraini!
- drewl
Was that a kit like other heathkit stuff?
Back in high school I had an electronics class, and I built a fuzz pedal kit as a project.
I think that was a Hallibar (sp?) kit though.
Anyone ever hear of Hallibar?
Maybe I should start another thread for that. I did some searching but have not found anything yet.
- pinkjimiphoton
- Contact:
yah, it was a kit.
built it the other day, nice fuzz for 1.5v!
made a daughterboard so i could run it at 9v, sounds a little tighter with the 9v...less sag.
here's the stupid pedal tricks video:
couple mods on the other forum, notably using 10k resistors at the ground ends of the tone stack, and swapping the 10k before the tone stack to either a pot or in my case a 3.9k resistor.
Slava Ukraini!
Slava Ukraini!
- LucifersTrip
- Contact:
yes...did you read the ad?drewl wrote:Was that a kit like other heathkit stuff?
https://i605.photobucket.com/albums/tt1 ... ooster.jpg
never heard of em...it would be cool if you could dig something up...around what year are you talking about?Back in high school I had an electronics class, and I built a fuzz pedal kit as a project.
Anyone ever hear of Hallibur?
you definitely have the spelling right (Hallibur)?
- drewl
Says kit right there, sorry.
Hmmm, Hallibar I built in high school would be around 1980/81.
I also turned a mini transmitter/reciever kit into a wireless.
Have no idea where those got to.
- pinkjimiphoton
- Contact:
screw it, i can't get this page to embed the damn video...
Slava Ukraini!
Slava Ukraini!
- LucifersTrip
- Contact:
remove the "s" from https
- pinkjimiphoton
- Contact:
thanks lu!!!
Slava Ukraini!
Slava Ukraini!
- johnk
I always wanted one of these so I finally got around to building one. mine is stock with the exception of adding a 1.5V voltage regulator(so it'll run on a standard 9V power supply), a relayed true bypass, led indicator and a clean Jfet output boost with level control. I LOVE this pedal!
- deltafred
- Opamp Operator
That sounds really good, definitely one to go on the "to build" list.johnk wrote:here's quick clip of it with a p bass thru my amp:
- ljn
- my favorite amplifier: Sears 125 xl, Kasino U100-P
- Completed builds: Fuzzrite (Si and Ge versions) , univibe, companion fuzz, fuzz face(si version), FY-6 super fuzz, FZ-1S, Scrambler, Tone Bender MkI (nearly complete). I have modded my vox v847,Seymour Duncan tweak fuzz, my bass and my guitar ( slightly).
- Has thanked: 7 times
- Been thanked: 7 times
You know, I read that Mark Farner of Grand Funk Railroad used a Heathkit TA-28 in the early,70s. I've heard some of their early stuff that he used it in and from what I can tell, it seems like a decent sounding fuzz. I may build one later on.
- pinkjimiphoton
- Contact:
these are really good fuzzes, they kinda remind me of a percolator in some respects tonally.
check diy for lucifer's trips notes on achieving unity gain, and how to drop voltage to get it to work with a regular supply.
fwiw, i make the pnp ge on mine, and it's incredibly rich and tube like... after seeing this thread i dug up my old layout and schematic, and am gonna probably build one of these today just for shits n giggles.
lot of fun!! don't get hung up on the transistors too much.. in my experience, most anything seems to work with a little bias adjustment.
it WILL be "cleaner" and less sputtery with a higher supply dropped down... try like a 7802 or something to drop it, or a couple diodes will work too if memory serves.
check my lame ass vid to get a taste of the tone.
happy building friends.
Slava Ukraini!
Slava Ukraini!
- ljn
It's definitely on my list of fuzz circuits that I want to build. I just have too many projects going on right now (mainly a couple of tone benders ). I'm thinking that I'd like to build it as the original schematic suggests. I don't mind a bit less output on a fuzz. Of course, I had read this was common problem with the Ampeg Scrambler. I built one of those and it's quite loud. I believe I have a vintage 2N3391 in a non working reel to reel. I'm definitely tempted to put one of these together, but I don't really have all of the required components at this time.
- drewl
Deja Vu
Got one of these in for repair and stumbled across this thread while researching it!
Wow, the volume is pretty low on these, lowering the 10k does help, raising the two 1k resistors really kicks up the volume!
I'm going to experiment with values to find a sweet spot of more volume while retaining the tone of the pedal.
