Montarbo - Sinfhoton ( Fuzz )
Re: Montarbo - Sinfhoton ( Fuzz )
Postby ik6gpy » 07 Dec 2011, 09:14
Hi Sinner,
These are the ones i've got on my hard drive. Hope it helps
Mat
For this message the author ik6gpy has received thanks: 2
moon-ra (31 Oct 2015, 06:00), sinner (07 Dec 2011, 09:31)
ik6gpy
Has thanked: 34 times
Have thanks: 25 times
Postby sinner » 07 Dec 2011, 09:32
Sure it helps bro, thanks :)
I was hoping to see SINPHOTON_schem2.jpg in better (bigger) quality, but this what I have should be ok
Has thanked: 1239 times
Have thanks: 1099 times
Postby ik6gpy » 07 Dec 2011, 10:00
Here it is... Better quality e bigger schematic
sinner (07 Dec 2011, 10:04)
ik6gpy
Postby sinner » 07 Dec 2011, 10:07
Thanks, you're my hero. So... We have 3 schematics in this topic and they're all different. Basic topology is the same, but some caps and resistor value differs. I bet they're all good, revisions and versions during production perhaps? But could you point me the best sounding one?
Postby sinner » 07 Dec 2011, 14:56
I've took factory schemo and did perf layout similar to stock one. There is not much gutshots on the web, I was limited to one only, but I think I nail it quite nice
For this message the author sinner has received thanks:
Nocentelli (07 Dec 2011, 22:40)
Postby LucifersTrip » 07 Dec 2011, 22:30
....was going to do a build report, but there didn't seem to be much interest at the time...
I did a bunch of tweaking and the only way this thing fired up for me was with high gain transistors and a bunch of resistor changes. Here's my final version with voltage readings:
For this message the author LucifersTrip has received thanks: 3
Belanger88 (06 Feb 2017, 16:20), Nocentelli (07 Dec 2011, 22:43), sinner (07 Dec 2011, 22:37)
LucifersTrip
Has thanked: 21 times
Have thanks: 85 times
Postby roseblood11 » 19 Dec 2011, 10:04
Can someone please upload a bigger version of the V2 veroboard layout?
It seems to be one of the many attachements that got lost during the server change...
roseblood11
Has thanked: 332 times
Have thanks: 304 times
Postby Solidhex » 20 Dec 2011, 18:59
Remove the 100K in parallel with the first set of clipping diodes for more fuzz...
Solidhex
Has thanked: 10 times
Have thanks: 17 times
Postby DesertCruiser » 26 Dec 2011, 22:09
Solidhex wrote:Remove the 100K in parallel with the first set of clipping diodes for more fuzz...
Yeah that would be the best thing to do if you want more bite to the sound. I really like this fuzz, very good for fat power chords and its very quiet, it kinda have this noise gate quality. My russian BMP clone got a rival :lol:
Don't recreate - create!
(exept when it comes to puttin' Mel Schacher in a box)
DesertCruiser
Have thanks: 31 times
Postby sunburnedgoat » 30 Dec 2011, 22:06
I breadboarded this and fell in love. It's the fat fuzzy characteristics of a Muff, but there is better string clarity and chords sound great on it. It also cleans up VERY well with the guitar's volume knob. I also like the very slight differences in the diode pairs' configurations, from the Muff's.
I built one on terminal strips, but still wanted a small enclosure, so I came up with a weird method. Definitely gotta build in layers! :D
sunburnedgoat
Have thanks: 2 times
Postby LucifersTrip » 30 Dec 2011, 22:32
sunburnedgoat wrote:I breadboarded this and fell in love.
very cool...and looks great!
did you make any changes? transistors used? collector voltage on Q2?
LucifersTrip
Postby sunburnedgoat » 31 Dec 2011, 00:08
Ahh, yes. The good stuff.
Q1 - B: .6, C: 1.96
Q2 - B: .58, C: 5.25
Mods: I used 10uf electrolytics in place of the 2.2. I removed the 100k parallel resistor in the first diode set, as recommended. Mine is the 2-knob version. I added a switchable .1uf cap to ground on the input, which opens it up a little more - a little bit of sparkle, subtle increase in vol and compression.
For this message the author sunburnedgoat has received thanks: 2
Korg (24 Jun 2013, 03:18), LucifersTrip (31 Dec 2011, 01:44)
sunburnedgoat
Postby sunburnedgoat » 31 Dec 2011, 00:18
Oh... and 2n5089. Both read about 580 hfe. Mine fired up immediately when I first put it on the board, and I didn't have to modify any resistor values in order to get it to fire up, as reported previously. It's a mean machine. Loud and dirty.
sunburnedgoat
Postby LucifersTrip » 31 Dec 2011, 13:31
sunburnedgoat wrote:Ahh, yes. The good stuff.
Q1 - B: .6, C: 1.96
thanx alot...I appreciate it. It's always cool to have other working voltages.
Did you try to move Q2C voltage up & down to see where you liked it best? I definitely wouldn't call what I got "dirty". I'd call it fat, chunky & smooth....with excellent sustain.
LucifersTrip
Postby DrNomis » 31 Dec 2011, 14:03
I wonder if MPSA 13, and MPSA 14 transistors will work in this circuit, I think I've got some stashed away somewhere, HFE is something like 10,000 or so.... :hmmm:
Has thanked: 123 times
Have thanks: 386 times
Postby LucifersTrip » 31 Dec 2011, 21:42
DrNomis wrote:I wonder if MPSA 13, and MPSA 14 transistors will work in this circuit, I think I've got some stashed away somewhere, HFE is something like 10,000 or so.... :hmmm:
I think I actually tried that and they didn't...you would have to re-design the circuit for darlington. I just went with the highest hfe I had, MPSA18
you should try em, anyway. my memory could be off.
LucifersTrip
Postby Nico3p » 24 Mar 2013, 21:06
Cambia qualcosa se al posto degli elettrolitici vengono montati dei condensatori al tantalio (per rendere più bassi i componenti)?
Nico3p
Postby johnk » 19 Sep 2015, 05:57
I just finished drawing up, etched and built a PCB for it and it sounds awesome.
I used MSPA18 transistors but had to adjust the two 10K collector resistors to get the transistors to sound good. with the stock 10K's I was only getting 1.6V on the collectors and although the circuit worked, it sounded horrible and very gated.
I replaced them 2.2K's and get 3.7V and it's smooth and silky.
I also added a gain control so I can lower the amount of fuzz if I want to.
here's the PCB layout:
For this message the author johnk has received thanks:
287m (19 Sep 2015, 19:00)
johnk
Has thanked: 31 times
Have thanks: 263 times
Postby johnk » 20 Sep 2015, 00:07
here's my completed build in an etched enclosure:
johnk
Postby Wiseblood » 26 Dec 2015, 06:39
Nice build johnk, what is that switching you're using?
Wiseblood
Has thanked: 71 times
Users browsing this forum: Dennie, rhandy gaye, Yazoo55 and 4 guests
