Proco - Rat ( History )
Postby dosmun » 12 Mar 2008, 15:27
For anyone that is a fan of the Rat. Here is a webpage I threw together.
http://webpages.charter.net/daosmun/
For this message the author dosmun has received thanks:
JshDnls (28 Jan 2011, 18:19)
dosmun
Re: Rat History
Postby Bernardduur » 12 Mar 2008, 17:14
Awesome.........
Anyone knows what happens inside a Juggernaut?
Bernardduur
Has thanked: 87 times
Have thanks: 489 times
Re: Rat History
Postby junkwork » 12 Mar 2008, 19:37
Juggernaut ver1.jpg looks so cool.
junkwork
Re: Rat History
Postby modman » 12 Mar 2008, 21:18
Haven''t look at everything, but :shock: looks like a lot of work went into that, wow. This is the kind of website that I like: a specific subject niche and first hand info).
bookmarked! :wink:
Has thanked: 3278 times
Have thanks: 611 times
Re: Rat History
Postby toneman » 13 Mar 2008, 14:31
VERY nice RAT website dosmun :thumbsup
8)
T
Tone-to-the-Bone
toneman
Has thanked: 100 times
Have thanks: 20 times
Re: Rat History
Postby alteredsounds » 13 Mar 2008, 16:06
Very cool, just what u want, all the facts, well laid out. Excellent :thumbsup (wish I could get my bloody Sola / Colorsound article finished that well!)
alteredsounds
Have thanks: 6 times
Re: Rat History
Postby dosmun » 13 Mar 2008, 16:55
Glad someone likes it. It was my first try at doing a website but it turned out OK. Most of the pedals are mine except for the Juggernaut which I don't own one yet and the R2DU but I did aquire one of those after I put the site up but never changed the pic, and of course the pic from the 1st 12 Rats made.
I'm not sure why ProCO started using a Log taper pot on the Filter control but the first issues that use a Linear taper sound much better because you have a lot more usable range.
I'm always up for suggestions or additions.
dosmun
Re: Rat History
Postby toneman » 15 Mar 2008, 18:07
hey dosmun,
try linking with other RAT sites. Especially those with Schemos... 8)
here are a few that I found while drinking coffee & googling.....
http://happybob.com/rstrand/rat/rat_versions.htm (good links for schemos AND history)
http://filters.muziq.be/model/proco/rat
http://diystompboxes.com/pedals/schematics.html
http://diystompboxes.com/pedals/PCRAT1.GIF
May all your RATS be wild!
afn
T
Tone-to-the-Bone
toneman
Re: Rat History
Postby Dirk_Hendrik » 16 Mar 2008, 20:05
:roll:
That schematic should be forbidden. Vanish off the surface of the planet. Be ritually burned or whatever. I'll leave it to RG to tell wether he has ever seen a RAT with a FET input buffer*. I haven't ever and I've seen a lot of RAT's over the last couple of years. However the positive feedback in this schematic (the gainn determining components should be connected to pin 2 and not pin 3 of the opamp) is the major definite error.
* Having seen newer versions by RG's hand make me suspect he knows :wink:
Has thanked: 255 times
Have thanks: 1035 times
Re: Rat History
Postby marshmellow » 17 Mar 2008, 09:04
Then you should also blame Jack Orman. He did the corrections. :shock: :hmmm:
marshmellow
Have thanks: 124 times
Re: Proco - Rat ( History )
Postby guiltyspark » 19 Mar 2008, 07:55
There are definitely some wrong schems out there, but I think the input buffer thing may be correct. I have a late 80's "LED in A" Rat with TWO transistors + IC, leading me to believe it has an added input buffer. The earlier non-LED Rats had ONE transistor and were better sounding IMO.
Guiltyspark
guiltyspark
Have thanks: 37 times
Postby analogguru » 19 Mar 2008, 09:13
guiltyspark wrote:There are definitely some wrong schems out there, but I think the input buffer thing may be correct. I have a late 80's "LED in A" Rat ....
Hows about guts ?
....with TWO transistors + IC, leading me to believe it has an added input buffer. The earlier non-LED Rats had ONE transistor and were better sounding IMO.
Guiltyspark
....because maybe the second transistor is used for LED-switching an not as an input buffer ? :roll:
Have thanks: 116 times
Users browsing this forum: No registered users and 7 guests
