EH - Clone Theory ( versions )  [schematic]
Postby Professor SourTone » 18 Mar 2008, 10:21
This was brought up on another forum, and in researching I found this page. I have two old Clone Theories, an earlier one with red graphics and an "edge" switch, and a later one with chorus/vib-vib/flange switch instead. I like the red one better, with the edge "on" always.
This site says they have different chips. It says the earlier version is based on the SAD1024 chip, and the later one on the MN3007. Is this so? I can dig them out and have a look, of course.
http://electroconducive.googlepages.com/ehxclonetheory
Professor SourTone
Have thanks: 40 times
Re: Clone Theory versions
Postby analogguru » 18 Mar 2008, 10:40
There were two versions, the early one from 1977 with SAD1024A and the 1980 version with MN3007.
They are similar but from a schematic viewpoint they are totally different - not only the BBD has been replaced, the complete circuit was reworked.
guts are always welcome, especially since I don´t trust the EH-1317 (SAD1024A) factory schematic.
Have thanks: 116 times
Postby Professor SourTone » 18 Mar 2008, 10:42
WilCo
Professor SourTone
Re: EH - Clone Theory ( versions )
Postby andregarcia57 » 26 Feb 2009, 21:43
hum... great!
andregarcia57
Have thanks: 86 times
Postby Professor SourTone » 27 Feb 2009, 00:21
Sorry, forgot - will attempt this w/e
Professor SourTone
Postby nelson » 27 Feb 2009, 17:27
Professor SourTone wrote:Sorry, forgot - will attempt this w/e
I'd love to see them too.
nelson
Have thanks: 9 times
Postby Professor SourTone » 01 Mar 2009, 17:04
Vib Flange version
Edge version
For this message the author Professor SourTone has received thanks:
GodSaveMetal (12 Jan 2014, 15:18)
Professor SourTone
Postby Professor SourTone » 01 Mar 2009, 19:38
Oddly enough the edge version has the MN3007 and the board layout looks similar to my uneducated eye.
Professor SourTone
Postby analogguru » 02 Mar 2009, 02:12
Thats not very astonishing. The edge version is from the end of 1979 and the other is from mid 1980.
Thanks for the pictures. Here is a different version, maybe the SAD-version.
Postby Professor SourTone » 02 Mar 2009, 09:42
That's interesting - so there appear to be 3 versions
SAD with Edge
EH 3000 MN3007 with Edge
EH 3000 MN3007 with VibFlange
Professor SourTone
Postby borislavgajic » 02 Mar 2009, 11:02
thanks for great pictures :applause:
borislavgajic
Have thanks: 248 times
Postby theehman » 02 Mar 2009, 18:58
Professor SourTone wrote:That's interesting - so there appear to be 3 versions
SAD with Edge
Are the slide switches in your units wired the same? Maybe you have a transitional unit?
Ron Neely II
fx schematics and repairs
theehman
Has thanked: 81 times
Have thanks: 85 times
Postby Professor SourTone » 02 Mar 2009, 19:17
They can't be wired the same because the functionality is different. There do seem to be a couple of extra caps on the trace side of one of the circuit boards. Unfortunately once again I do not have the units with me...
Professor SourTone
Postby theehman » 02 Mar 2009, 19:37
Professor SourTone wrote:They can't be wired the same because the functionality is different. There do seem to be a couple of extra caps on the trace side of one of the circuit boards. Unfortunately once again I do not have the units with me...
I think those caps are on the back of the board due to space reasons.
Ron Neely II
theehman
Postby V1nce69 » 10 Nov 2013, 09:22
I own a vintage Clone Theory that is an EDGE SAD version.
Here are some pictures of its guts:
May be these can be of some interest to all of you. :D
Vince
For this message the author V1nce69 has received thanks: 6
Bernardduur (10 Nov 2013, 15:35), candidate (11 Nov 2013, 03:55), floris (01 Jan 2018, 17:58), lolbou (11 Jan 2014, 10:22), mister707 (12 Nov 2013, 17:50), phibes (11 Nov 2013, 20:07)
V1nce69
Has thanked: 30 times
Have thanks: 61 times
Postby Scruffie » 09 Jan 2014, 19:19
Having traced through those MN3007 units above (they are both wired the same for the edge switch so I don't know why they sound different but the edge one is just a transitional model) I think i've discovered that both Tom Boy and subsequently Nelsons schematics are incorrect, here's what i've got so far;
This applies to the Nelson schematic;
No - C19
No - C20
No - C7
C22 - 560pF
C17 - Possibly 220nF?
R33 & 34 - 220k
5k Cancel Trim (No R10 & 11)
C8 - 100nF
R21, 22 & C14 wrong, R22 (160k, maybe 150k on the other unit) and R21 (1k?) with switch pole coming from the center, R21 goes through 100nF to ground.
Output, Pin 7 through 1k? (switch pole connects here) with ?? Cap to ground in to ?? Output cap with 100k pull down.
If anyone has a unit that can help confirming all the cap values and those 3 questionable resistors that'd be a help in getting a correct schematic.
Scruffie
Has thanked: 27 times
Have thanks: 138 times
Postby phibes » 10 Jan 2014, 16:01
Email me Scruff, I got a SAD1024 unit.
Image Ken
phibes
Has thanked: 85 times
Have thanks: 185 times
Postby Scruffie » 11 Jan 2014, 03:52
As far as I can tell, this is now 100% correct for the MN3007 version except for the values of C5 & 6 which I have left as 680pF for now as the original has a cap labelled 412 and I cannot confirm what the actual value is, both 412pF and 4,1nF seem like very odd values.
Vib Flange Switch is shown incorrectly, 2nd half should be in N.C position and the input opamp should be U1A - RC4558.
Thanks to pinkjimiphoton for confirming some values from his original units.
For this message the author Scruffie has received thanks: 7
bato001 (19 May 2014, 23:04), floris (01 Jan 2018, 18:00), GodSaveMetal (12 Jan 2014, 15:18), Intripped (19 May 2014, 22:04), IvIark (18 May 2014, 14:10), pinkjimiphoton (19 May 2014, 21:57), tp801 (11 Jan 2014, 23:24)
Scruffie
Postby pinkjimiphoton » 19 May 2014, 21:59
alright, ya got it done!! sweet!! i wanna build one now, cuz the other one is similar (the toppopiccione site one) but i think it's a modded small clone, not a clone theory.
the actual mn3007 clone theory is THE one to have. the sad1024 version with the "edge" switch is pretty much a "feature" that lets the full frequency of that hiss come thru... ;)
pinkjimiphoton
Has thanked: 224 times
Have thanks: 345 times
Postby Scruffie » 19 May 2014, 23:11
pinkjimiphoton wrote:alright, ya got it done!! sweet!! i wanna build one now, cuz the other one is similar (the toppopiccione site one) but i think it's a modded small clone, not a clone theory.
Nah the toppopiccione one is a clone theory, only the filtering & feedback is a bit wrong, there's some unnecessary parts and a few wrong values.
But yup, got it all confirmed and eventually got hold a copy of the factory schematic, my redraw is correct.
Keep an eye on the madbean forum in the next few days too :wink:
Scruffie
Next
Users browsing this forum: shredgd and 4 guests
