Page 5 of 6
Re: ESR Graphic Fuzz
Posted: 28 Jan 2015, 00:19
by storyboardist
Posted: 28 Jan 2015, 10:15
by deltafred
induction wrote:Sorry, I guess my post came out snarkier than I intended it.
No worries (as Dr Nomis would probably say), I was probably a bit abrupt in my first post, it was near midnight here and I'd had a few scotches. Never a good idea to post (or go on Ebay) when you've had a few.
(I saw your post yesterday but was on my tablet and can't be doing with typing on those poxy little touch keyboards.)
Posted: 29 Jan 2015, 14:16
by storyboardist
Selfdestoryer verified my layout last night. The above image is wrong though. Here's a link to the verified layout:
http://effectslayouts.blogspot.com/2015 ... -fuzz.html
Posted: 08 May 2015, 01:52
by EBRAddict
It was mentioned earlier in one of the ESR Graphic Fuzz threads here or at DIYSB that this circuit is sensitive to the source impedance feeding pin 2. It doesn't like it. In fact when I had my bass roll-off knob engaged on the guitar all the pedal would do is squeal.
I put a simple JFET buffer feeding pin 2 of the 741 op amp and the squealing/oscillation went away. The circuit I used is straight from muzique, I subbed 1.5M resistors for the 1M because I have a bunch and used a 2N5457 JFET:
In that configuration it has a high input impedance, low output impedance, and near unity gain. From the 10uF I went straight to pin 2 of the op amp and pin 2 of the Filter pot.
Also earlier, larsj contributed that adding a potentiometer between pins 1 and 5 (the offset null setting) produced some interesting results. The datasheet for the LM741CP says to use a 10k linear pot, I grabbed a 50k linear by mistake, but playing around with the pot you can generate a square wave or a sawtooth wave at the output, and several interesting permutations in between and at the extremes. The sawtooth and square wave generate very different harmonic profiles.
Posted: 11 May 2015, 01:09
by greenskull
Thanks for revisiting this circuit! I had a go at it on the breadboard some years back, but for some reason I didn't commit to a build. I think I'll give it another shot and try some of those tricks.
I wish I knew what John over at Basic Audio added to his version of this pedal...... it sounds extra nasty!
Posted: 12 May 2015, 23:28
by EBRAddict
greenskull wrote:Thanks for revisiting this circuit! I had a go at it on the breadboard some years back, but for some reason I didn't commit to a build. I think I'll give it another shot and try some of those tricks.
I wish I could go back and edit my previous post. That JFET buffer makes the "FREQ" pot practically useless. You still get the crazy fuzz and it kills the out of control oscillation, but it kills the frequency resonance effect. I put mine on a DPDT bypass switch for when I want the fuzz but none of the squeal. The pedal needs direct interaction with the guitar's controls without a buffer to get many of the sounds out of it.
I also added a squeal tamer as others have shown in the posts above, along with a switch to go back to stock. It keeps some of the functionality of the FREQ pot like the weird sub-clipping resonance and just a tiny bit of squealing, but not the crazy oscillation every time I stop playing.
Posted: 29 Jul 2015, 05:59
by petey twofinger
so if one woud use active pick ups , would this in fact negate the filter effect knob , or change the effect ?
dont mind me i am slow
Posted: 20 Aug 2015, 16:40
by EBRAddict
petey twofinger wrote:so if one woud use active pick ups , would this in fact negate the filter effect knob , or change the effect ?
I'm not sure what the output impedance of active pickups looks like but I would say yes. I have a bass roll-off on my guitar and when engaged it rendered the effect useless.
Posted: 01 Dec 2015, 15:20
by allesz
Finally I made this one :horsey:
Tried the first schemo, without input and output caps, but it did not work.
Then tried the later schematic with the regular power rail, and it worked at first try; the soud is very similar to the YT videos.
It's a funny pedal, but I think I won't box it right now, the feedback is nice, but makes the use of the thing quite limited. I like it also because, like, the hot cake (a totally different animal, I reckon), it overdrives the IC without diodes.
I did some experiments with the 0,1 uF and 200R output network: it seem to have a big influence on the feedback, and I thin it can help tuning it.
I really still don't understand how it works: if the 1M pot was a fixed resistor I would say it's just an inverting IC amp with ultre high gain.... but since the pot is just a variable resistor I really can't explain how it works. Strange beast.
Posted: 10 Apr 2016, 16:35
by zosotone
Can I use the TL071? I have built the vero from tabbycat and I have no sound.
Some oscillation but nothing more. The 9v and ground are the common true?
Posted: 10 Apr 2016, 18:55
by roseblood11
Missing trace cut under R5 - you have connect the level pot to +9V.
Not very healthy for the folowing pedal and for C6...
Never use a layout before you've compared it to the schematic!
Posted: 11 Apr 2016, 17:09
by zosotone
Well, I thought the layout was verified, in theory works well. So, the cut under R5 it's wrong?
Posted: 11 Apr 2016, 17:40
by Nocentelli
The vero IS supposed to be verified, I think roseblood is suggesting that IF you missed that hard-to-spot cut under R5, this would send 9v DC direct to the output.
Posted: 23 Apr 2016, 21:30
by zosotone
Finally, I've done the vero from Tone Report Weekly Issue 118 http://www.magazine.tonereport.com/tone ... 1457730164
Page 40-48
I've added a volume pot after the level. Sounds amazing, full and organic but the filter pot only works well backward for my taste. How can I set the filter at minimum? maybe with a low value resistor between wires filter 2 and 3?
Posted: 24 Apr 2016, 12:33
by tabbycat
zosotone wrote:Well, I thought the layout was verified, in theory works well. So, the cut under R5 it's wrong?
hi zosotone, the original (larger) layout i did for this is earlier in this thread ( https://www.freestompboxes.org/viewtopic ... 60#p247467 ). that one i built and works great. 1-1 with the main demo on yt.
i revisited it a while later and realised if i jiggled a couple of components around it could be a few rows smaller for those who like compact layouts. as the r5 cut then moved to under the resistor (though still just visible through the colour) i added an additional written note to the layout just in case anyone missed it.
i haven't built the second layout (though it is fundamentally the first just compacted, which i have built) but members at gfx have and reported good results.
it also might be worth swapping lm741 just in case you have a faulty one. i read somewhere that there are different types of lm741, some which will work and some which don't. have just had a quick google but can't find that forum post quickly,
but i remember that issue coming up somewhere. perhaps it's in the suffix. some are marked lm741tc and some lm741ua or something alone those lines.
sorry to hear you haven't been able to get a good result. as i say, i built the first layout and got excellent results. the subsequent compacting of the layout was pretty minimal, just shuffling things left or right to tidy up but maintining the basic topography.
Posted: 07 Aug 2016, 16:21
by peepsthecat
3 years later... I wanted to try an op amp on eyelet board, back to the Graphic Fuzz. It sounds better to me than the 1st vero layout I posted- more responsive and tamable with the guitar volume/filter. Must be the mojo parts. Either ua741 or lm741 work fine as long as they are Texas Instruments.
Posted: 08 Dec 2017, 08:38
by traktop
So the tabbycat working layout is the one posted above by zosotone, (dated on 25-42015), right?
Posted: 13 May 2020, 08:16
by modman
Some pictures of a unit in the original box
Re: Earth Sound Research - Graphic Fuzz
Posted: 16 May 2020, 01:00
by Rambozo96
Wasn’t this based on the Anderton comparator Fuzz?
Posted: 21 Jan 2023, 07:28
by Intripped
Sorry for the OT:
Someone sent an email to me asking questions on the graphic fuzz, username starting with letter B... (just remember this).
thinking that it was just the notification of a PM, I deleted the email, and came here on the site to answer him, but it WAS an email!
He was asking about the choice of 10V green ceramic caps, if this had any particular reason or sonic impact.
My answer is:
Regarding the sonic impact I have no idea. Capacitors' sound is a very problematic matter, it always generates flames between scientists and believers.
My suggestion is to try and experiment, and grow your own idea.
It's true and scientifically proved anyway, that CERAMIC capacitors do have a sonic impact because they could be microphonic and also generate some kind of distortion on audio signal; it depends a lot on the ceramic material though. Some are much different than others.
- 10V is very close to 9V (or viceversa) and that makes those capacitors work close to their limit -
could be, but it also depends on where those caps are in the circuit: they can also have a smaller voltage drop than full 9V.
And there is always a little safety margin with capacitors' voltage ratings, so that you can impose the full voltage with no problems (usually).
