Univox - Impersonator ( UEQ-375 )
- MoreCowbell
I found several refereb=nces to it, but no thread with the schematic...so HERE it is.
<crap - I just saw that this was made in 1976, so if you could move it to the "post 1975 forum" I'd appreciate it AG>
- Univox - Impersonator ( UEQ-375 ) schematic
- impersonato.gif (10.88 KiB) Viewed 1455 times
- analogguru
Schematic contains mistakes....
This forum is ok for this unit.... The split is only approx. 1975 and more important is the split between the Boss/Ibanez/Dod (FET-switched) small-boxes stuff.
- MoreCowbell
OK, thanks.analogguru wrote:Schematic contains mistakes....
I know this unit has been mentioned because of the inductor based EQ in, IIRC, the Fulltone GT500 thread among others.
May I inquire what the errors in the schematic are ? Just curious.
- analogguru
Have a look at the schematic below - can you find the difference ?
with the given component values the center frequencies of the filters are:
205 Hz, 430 Hz, 734 Hz and 3 kHz which seems to be reasonable.
- MoreCowbell
IC1B ground connection.analogguru wrote:Have a look at the schematic below - can you find the difference ?
Oh, and the "Drawn by Per Cederholm 05-05-02"
- pinkjimiphoton
- my favorite amplifier: my own, a redesigned princeton
- Completed builds: so fucking many goddamn pedals it would make your ass hurt just looking at 'em all!!!!!
there's videos that totally suck of about 90 of 'em here:
http://youtube.com/666pinkster
gimme a like: http://facebook.com/pinkjimiphotonrocks - Location: new world order land (formerly la-la land)
- Has thanked: 358 times
- Been thanked: 480 times
- Contact:
sorry to bump a zombie back to life and all, but i just copped one of these on evilbay for a paltry sum.
dead on arrival. first suspect were the three electros. replaced 'em, 2x 10uF and 1 100uF. fired up with a squeal. solder bridge. ooops.
fixed that, wango!! this thing actually sounds fairly good!
will not run on a 9v wart, despite having a 9v input jack. gotta be 18v i'm assuming, as 2 batts work great. ... very clean, very loud, you can def shade between different guitar tones and, well, "impersonate" them.
so anyways.... midrange 2 slider is broken, anybody got a good replacement for this they can reccomend? it's 1.34" long and seems to have 4 connections to the board. must admit i'm not used to slider pots, so advice is appreciated!!
thanks!
jimi
thanks!
jimi
Slava Ukraini!
Slava Ukraini!
- pinkjimiphoton
- Contact:
modman asked me to get some pics and verify the component values in the contested schematic,
i can't see well enough to read the damn values, but here's some phone pics for now...
the schematic is also missing a small transformer apparently...
Slava Ukraini!
Slava Ukraini!
