Jen - Motorphaser
Jen - Motorphaser
Postby 777seven777 » 19 Nov 2014, 21:15
Hi
I'm trying to fix a JEN Motorphaser, but I don't have a schedule, does anyone here in the forum have something they could share.
//sven
777seven777
Have thanks: 6 times
Re: Schematic for Jen Motorphase
Postby karul » 19 Nov 2014, 22:34
Can you post some pictures of it, both sides ?
karul
Has thanked: 221 times
Have thanks: 151 times
Postby 777seven777 » 23 Nov 2014, 19:14
I have attached the photos, I hope you can see them, I get sound through the pedal but I cannot get the modulation to work.
//sven
For this message the author 777seven777 has received thanks: 2
modman (06 Jul 2017, 22:39), rocklander (23 Nov 2014, 23:11)
777seven777
Postby tube-exorcist » 23 Nov 2014, 20:06
777seven777 wrote:I have attached the photos, I hope you can see them, I get sound through the pedal but I cannot get the modulation to work.
//sven
Nice that you have an iPhone 5. Now you only need a better light, a stable hand and you have to find the macro setting (most of the time a flower symbol) to make sharp and usable pictures.
tube-exorcist
Has thanked: 210 times
Have thanks: 77 times
Postby 777seven777 » 23 Nov 2014, 20:32
I will bring out my real camera..
Nocentelli (23 Nov 2014, 20:58)
777seven777
Postby 777seven777 » 23 Nov 2014, 21:45
These are a lot better
modman (14 Feb 2016, 18:07), rocklander (23 Nov 2014, 23:10)
777seven777
Postby rocklander » 23 Nov 2014, 23:15
thanks!.
now can you please identify the following 25 components for us? (values/part numbers).
rocklander
Has thanked: 1578 times
Have thanks: 289 times
Postby tube-exorcist » 23 Nov 2014, 23:53
rocklander wrote:thanks!.
25.....
now the big silver cans are 741,...
- 7 makes 18...
the round transistors are 2N5163 FET´s, .....
- 5 makes 13....
the light blue electrolytic is 100µ/25V,...
- 1 makes 12....
the trimmer beside this electrolytic is 22k....
- 1 makes 11...
the trimmer beside the 1M resistor on the left side is 220k...
- 1 makes 10....
yes and if you take a Mxr Phase 90 schematic on your desk while tracing it can be helpful....
For this message the author tube-exorcist has received thanks: 2
modman (14 Feb 2016, 18:07), rocklander (24 Nov 2014, 21:11)
tube-exorcist
Postby tube-exorcist » 24 Nov 2014, 01:07
...and for the LFO section have a look at the Maestro PS-1A/PS1B (v2 + v3) schematic.
tube-exorcist
Postby sinner » 24 Nov 2014, 01:20
Can I have the pots values?
I will rework the pcb and get the schematic done by the middle of the week
Has thanked: 1240 times
Have thanks: 1099 times
Postby 777seven777 » 24 Nov 2014, 20:49
I have checked all pot values, there is also a bipolar capacitor. And I have added data for the Three transistors, hopefully you can read the text..
777seven777
Postby sinner » 24 Nov 2014, 21:50
Cool. I will start to roll it tonite
What's the board dimensions in inches?
Postby 777seven777 » 24 Nov 2014, 22:14
It is 110x88 (in millimeters)
777seven777
Re: Jen - Motorphaser
Postby smilan » 04 Jul 2017, 23:36
I know this post is quite old but I need some help with fixing my motorphase.
A friend of mine wave me this Jen Motorphaser pedal in un-working condition.
Since I can not find the schematics for it I need some help with rewiring this pedal.
The two wires coming from the output jack are cut and I don't know where to connect them?
I made this sketch that shows the connections between the PCB board to the input / output jacks and to the switches.
Besides the cuted wires I've noticed that the former owner replaced many components on the board.
I would like to recap all the film caps with new wima caps.
The opamps on the board are ca741ce, those are the original opamps for this pedal?
What about the transistors?
there are five u1899e (round ones) and two bc238b, those are the right ones?
For this message the author smilan has received thanks:
rocklander (05 Jul 2017, 02:28)
smilan
Postby smilan » 05 Jul 2017, 22:17
So I've wired the output jack and the effect working now, but my problem is that when I'm setting the trimmers I'm getting good sound but after few seconds the phaser effect fades and I need to play with the trimmer to get the phaser back, but after few seconds it's gone again. See this video and see this problem:
Link
What components on the PCD can causing this kind of problem?
smilan
Postby fuzzbunny » 06 Jul 2017, 08:52
Maybe the trimmers are the problem?
Try hitting them with Deoxit.
fuzzbunny
Have thanks: 10 times
Postby smilan » 08 Jul 2017, 21:32
So I think I've managed to repair my pedal!
I replaced all the 741 op amps with new ones, I've also I replaced few trimmers and one bad resistor and now it's rocking again!
There's still some notable noise coming out from this pedal, but I don't know if this is how it works or there's something else to check?
This is how it sounds:
https://youtu.be/3cwQj-jiFXc
smilan
Users browsing this forum: brejna and 1 guest
