Non fuzzing fuzz - ELK Fuzz Wau
fuzzbuzzfuzz
Post by fuzzbuzzfuzz »
**please move if in the wrong forum spot thanks**
Repair help requested if possible.
Picked up a "junk" fuzz on Xmas day - an ELK Wau Fuzz. It's an early 70s large treadle monster with a tone foot switch. It should by rights produce a clanging octave fuzz noise as underneath its guts are essentially a Shin Ei 6 transistor super fuzz. But as of now it's simply out putting a mild overdrive. I've had the multimeter over it - no obvious voltage black holes.
Any potentially obvious solutions spring to mind before I delve deeper?
Perhaps a dodgy transistor? Irvtepkacevthosebold caps?
I spent a good few fruitless hours today frustratingly stumped by it!
Thanks all in advance!
fuzzbunny
Has thanked: 60 times
Been thanked: 14 times
Post by fuzzbunny »
1) Cleanup solder traces on pcb
2) Verify with matching schematic
3) Follow singnal path with Audio Probe
4) Have fun!
lolbou
Has thanked: 308 times
Been thanked: 225 times
Post by lolbou »
I would audioprobe first. And have a look at these electros then...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
fuzzbuzzfuzz
Thank you for your input gentlemen. This one is proving a challenge.
I measured the voltage across the circuit and located a few dead spots or low voltage points. In lieu of that I saw a couple of transistors had almost no volts running across them. I socketed two. I also recapped the electrolytes. Slight improvements. The annotated diagram is before I socketed the transistors.
Whilst fiddling I noticed that by gripping the board by one corner (lower left in the picture) with my thumb connecting the circuit trace points for a green cap and resistor - that a full fuzz sound emerged albeit noisy. Without applying pressure unfortunately silence. I replaced that cap then the resistor alongside but the same effect.
..and then a high pitched squeal emerged and I quit for the night!! I now also see a full voltage across a socketed transistor which can't be correct..
Two steps forward and several back it seems.
The high pitched squeal noise - bad soldering?
My thumb connecting the two components...grounding them?
Any thoughts much appreciated as always.
fuzzbuzzfuzz
Note: The "X" in the lower left is one of the resistor points measuring 0 volts. Below is a .047 greenie cap (now replaced). The next point up is also a .047 cap.
Do green caps leak and require replacement due to aging?
What is a good method of cleaning up the board traces?
In soldering a few trace connection points lifted but I believe I rescued them. It's s messy old board with poor soldering all over.
I need to remember to have fun with it though!
ljn
my favorite amplifier: Sears 125 xl, Kasino U100-P
Completed builds: Fuzzrite (Si and Ge versions) , univibe, companion fuzz, fuzz face(si version), FY-6 super fuzz, FZ-1S, Scrambler, Tone Bender MkI (nearly complete). I have modded my vox v847,Seymour Duncan tweak fuzz, my bass and my guitar ( slightly).
Been thanked: 7 times
Post by ljn »
I don't think those green caps go bad with age. At least, I haven't come across a bad one yet.
