Rangemaster and Electra distortion grounding
I am planning to build multiple circuits, pnp and npn in one metal enclosure, each with its own input and output jacks, each with separate power supplies. Will positive grounds and negative grounds , those from the output jacks making contact with the enclosure be a problem?
- Nocentelli
- Has thanked: 1152 times
- Been thanked: 954 times
You would be better off powering them all from the same "negative ground/positive power" DC supply, but use a voltage inverter on a daughterboard for the pnp "positive ground/negative power" circuit.
- BJF
You could also convert all to the same polarity as in all NPN or all PNP.....
But you could power all from the same supply while you will have to decide which pole is ground-for AC signals both B+ and chassi are the same point;) meaning that both become AC ground. All you need to do to combine PNP and NPN from same supply is to keep track of the currents needed for them to work and then just decide which pole should be common chassis ground - it helps hum if you build a b-tree and voltages at each tap are easily computed with Kirshoff's laws
Have fun
BJ
Have fun
BJ
