Guild Brian May Power Booster(treble boost)
Postby Belanger88 » 07 Mar 2017, 07:10
is it just me or does this guild brian may pedal have far less components then the vero layout from tagboardeffects. Thanks for any input a head of time
Success is no accident. It is hard work, perseverance, learning, studying, sacrifice and most of all, love of what you are doing or learning to do.
Belanger88
Has thanked: 99 times
Have thanks: 29 times
Re: Guild Brian May Power Booster(treble boost)
Postby Belanger88 » 07 Mar 2017, 14:10
I think the difference is a cornish buffer in front of the one and this one uses slightly different cap values for a couple
For this message the author Belanger88 has received thanks:
Manfred (12 Mar 2017, 15:59)
Belanger88
Postby Belanger88 » 07 Mar 2017, 17:57
hopefully, someone will find these useful! I'll try to post good pics of the ts808dx next. I also have the amptweaker tight boost we could trace as a group but it's going to take a lot of help from some of you more senior members of the community as it's a lot to trace for sure
deltafred (08 Mar 2017, 00:21)
Belanger88
Postby Manfred » 12 Mar 2017, 13:01
I made a PCB layout derived from the shots and found the schematic by tracing.
C6 is a guess following the Brain May Box.
http://www.next.gr/uploads/9/Guild_BrianMayBox.gif
I would say that the value of P1 shoud be a least 250 to 500 Kiloohms
How knows the real values of the original pedals?
Belanger88 (14 Mar 2017, 19:04), stomper (12 Mar 2017, 13:07)
Has thanked: 902 times
Have thanks: 436 times
Postby Manfred » 12 Mar 2017, 13:11
The edit button did not appear. :?:
Rocket Roll (12 Mar 2017, 22:45)
Postby Manfred » 14 Mar 2017, 01:04
I forgot the PCB-Layout.
Print the PDF-file using the original size setting.
GuildBrianMayBoostPCB.pdf
Postby smackoj » 14 Mar 2017, 06:05
I do not know for sure what the Brian May Treb Booster values are, but I know that I have built the General Guitar Gadgets version and it sounds great. I prefer the Brian May over the Dallas Rangemaster by far. So, if anyone wants to compare and contrast the schematic and values, here is a link to the GGG Brian May Booster. Their website would not let me copy or download the info so you'll have to follow the link. Sorry. http://www.generalguitargadgets.com/eff ... e-booster/
smackoj
Has thanked: 18 times
Have thanks: 6 times
Postby Manfred » 14 Mar 2017, 11:17
The Brian May Treble Booster has a input inpedance less than the Guild Brian May Box has.
The input circuit of the Box is a bootstraped common collector circuit, which provides a higher input impedance
I calculated it and found an input impedance of about 400 Kiloohms for a hFE of 200.
Therefore, I think a value range from 250 Kiloohms to 500 Kiloohms for P1 make sense.
Ultimately, however, only using trial and error bring the truth to the light.
In comparison to the other circuits result a value range of 4.7nF to 6.8nf fo C6.
Postby Manfred » 14 Mar 2017, 11:52
PCB-layout with corrected trace width to 0,04 inch.
GuildBrianMayBoost2.pdf
Postby Belanger88 » 14 Mar 2017, 19:07
Thanks, Manfred! appreciated, it may be cool to build into some preamp pedals as an option boost. I've going to modify the King Of The Britains to have a slightly more low end and then have this bad boy driving that
Belanger88
Postby Belanger88 » 14 Mar 2017, 19:13
if I had the pedal in hand I would verify the pot value's for you but I don't unfortunately I figured there are some pretty brilliant people on here tho and the circuit is really basic so someone could make sense of it
I'm pretty sure the cap in question is 6.8nf but I can't be sure either
Belanger88
Postby LulaNord » 31 Mar 2017, 19:47
Hi...as per my knowledge The input circuit of the Box is a bootstraped common collector circuit, which provides a higher input impedance.I calculated it and found an input impedance of about 400 Kiloohms for a hFE of 200.Therefore, I think a value range from 250 Kiloohms to 500 Kiloohms for P1 make sense.Ultimately, however, only using trial and error bring the truth to the light.
LulaNord
Users browsing this forum: whopperplate and 2 guests
