Jordan Bosstone...Output cap required?
Postby d rock » 12 Jun 2017, 10:03
So I've been playing around with this circuit on a breadboard. The capacitor sizes are a big key in this circuit so I've been switching them out. .068uf input cap and .047uf cap to ground. I have had anywhere from .022uf to .1uf as output, and bigger tended to sound better to me. So eventually I was running this into a harmonic perk variant that I built and decided to try removing the output cap from the bosstone. I really couldn't notice much difference, if anything the sound got a little bigger but about the same.
So my question is, do you really need a output cap on this circuit or is there something bigger that I'm missing. I'm fairly new to building my own circuits so I might be missing something big here... Any thoughts?
d rock
Re: Jordan Bosstone...Output cap required?
Postby mirosol » 12 Jun 2017, 18:22
Without that cap you'll have the same dc voltage at the output as the second transistor. So yes, you defnitely need the cap there. Try 1u-2,2u (positive to circuit - negative to output) and you shouldn't lose anything from the signal due to too small cap.
+m
mirosol
Has thanked: 146 times
Have thanks: 330 times
Users browsing this forum: Yahoo [Bot] and 10 guests
