Real or Fake Reticon SAD1024 Chips?
Postby pmkipp » 25 Aug 2017, 16:09
They look kinda fake, being purple and all. But the lettering is correct.
These are in a non-working 1977 Memory Man (3 knob, solid gray version). Just some mild squealy noise when the effect is engaged.
These have, besides the purple color and the metal label, gold pins and are mounted in sockets.
Anyone ever seen anything like this?
Pete
Pete's Pedals, St Louis
Pete's Pedals
St Louis, MO
pmkipp
Has thanked: 15 times
Re: Real or Fake Reticon SAD1024 Chips?
Postby Scruffie » 25 Aug 2017, 17:25
Yeah those are real, just an older package type.
For this message the author Scruffie has received thanks:
pmkipp (25 Aug 2017, 20:14)
Scruffie
Has thanked: 27 times
Have thanks: 138 times
Postby Dirk_Hendrik » 27 Aug 2017, 19:30
With a nano-error margin I'd say real. I cannot imagine someone would be willing to create the most alternative looking ceramic DIL case for a counterfeit. Those should be looking as normal as possible.
Other than that,
In the many, many, BBD based effects I've fixed it was almost never the BBD chip. Don't step into the common misconception that the defect will probably be in the most expensive or rarest part. I's usually not.
For this message the author Dirk_Hendrik has received thanks:
pmkipp (08 Sep 2017, 00:23)
Has thanked: 250 times
Have thanks: 1004 times
Postby theehman » 28 Aug 2017, 21:40
Definitely real. Common in very old Memory Man pedals, especially the gray ones.
Ron Neely II
fx schematics and repairs
For this message the author theehman has received thanks:
theehman
Has thanked: 81 times
Have thanks: 85 times
Postby lolbou » 28 Aug 2017, 22:04
Had one stock in a Deluxe Mistress that matched the very Hendrik's criteria :wink:
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
For this message the author lolbou has received thanks:
lolbou
Has thanked: 346 times
Have thanks: 236 times
Postby pmkipp » 08 Sep 2017, 00:26
Problem is not with the chips. There is too much power going in through the filtering. 32 volts prior to the regulator, builds up to 22 volts after when plugged in. Will rebuild the entire section and cross fingers...
Pete's Pedals
St Louis, MO
pmkipp
Postby pmkipp » 10 Sep 2017, 13:41
Well - seems the problem may be with the chips, unless someone has another suggestion to check. Before I got this, when plugged in there was up to 22 volts going to the 1024 chips. The main problem in the power section was too much power coming out of the transformer (not the end of the world) and a bad Zener. Now, with a new beefier Zener and a higher value power resistor, the voltage coming out of the regulator is a cool 14.7 volts. But, pedal still did the same squealy noise with no effect. I traced the signal and all was fine all the way to the input leg of the first 1024, and the squeal began (mildly) on the output of that chip and increased through each one until total noise on output of the third. Bummer. I am assuming the chips were exposed to too much voltage for too long, but i am not an expert... If anyone is interested I can provide some voltage readings on each leg of the 1024's, or anywhere else. :hmmm:
Pete's Pedals
St Louis, MO
pmkipp
Postby theehman » 10 Sep 2017, 16:04
Did you try adjusting the bias on each 1024?
Ron Neely II
pmkipp (11 Sep 2017, 00:24)
theehman
Postby Scruffie » 10 Sep 2017, 16:50
They wont work without a clock signal so you need to test the 4047 is working too which IIRC has a lower terminal voltage than the SAD1024.
I'd post voltages if I were you.
pmkipp (11 Sep 2017, 00:25)
Scruffie
Users browsing this forum: No registered users and 8 guests
