Shin-ei Mute Box  [schematic]
Postby Addy Bart » 17 Jan 2018, 00:20
Saw this on a local listing and thought it might be of interest here.
For this message the author Addy Bart has received thanks: 4
karul (17 Jan 2018, 17:17), modman (18 Jan 2018, 10:25), Nocentelli (17 Jan 2018, 19:14), Zokk (21 Jan 2018, 13:48)
Addy Bart
Has thanked: 27 times
Have thanks: 8 times
Re: Shin-ei Mute Box
Postby Nocentelli » 17 Jan 2018, 19:22
Schematic appears to omit the actual filter section :scratch: I can't see how the envelope controls the filter sweep
Nocentelli
Has thanked: 871 times
Have thanks: 839 times
Postby tube-exorcist » 18 Jan 2018, 02:03
Nocentelli wrote:Schematic appears to omit the actual filter section :scratch: I can't see how the envelope controls the filter sweep
Hmmm... maybe the led illuminates a double LDR which is symbolized by 4 dots inside a circle (in the left lower corner - in parallel to R19, R20) ?
tube-exorcist
Has thanked: 210 times
Have thanks: 77 times
Postby Addy Bart » 19 Jan 2018, 00:16
I think you're right. I found a discussion about these 4 dots here, and it appears to be a dual photoconductive cell.
http://archive.ampage.org/threads/1/fxs ... III-1.html
Addy Bart
Postby Nocentelli » 19 Jan 2018, 15:26
It seems to be a virtually the same as the Mutron III, which uses a dual LDR/single LED optocoupler - Marked with the question mark in the pic below:
Addy Bart (20 Jan 2018, 04:53)
Nocentelli
Users browsing this forum: No registered users and 6 guests
