Eko - Multitone  [schematic]
Postby Bononoob » 15 May 2019, 02:17
I traded and repaired a Eko Multitone a while back. Apparently it's the firt multi-effect ever.
It has Wah (called Strepitoso in italian), Treble/Bass Booster, Distortion and Repeat (percussion tremolo).
So I traced the 4 different circuits, you can find attached the schematics and some pics.
FS33805 are npn BJT with 1:C 2:B 3:E pinout. I tested one and hfe was 216. BC208 is apparently an equivalent and if i'm not mistaken 2n3904 could do the job.
4JD5E44 is a UJT (maybe equivalent to 2n2646 ?)
I hope I got it right the first time, but if you find anything weird on one of the circuits, point it out and I'll check the board
For this message the author Bononoob has received thanks: 13
alexradium (15 May 2019, 11:49), digi2t (15 May 2019, 03:27), fuzzbunny (15 May 2019, 06:14), FUZZZZzzzz (17 Oct 2019, 11:25), Intripped (15 May 2019, 15:57), karul (18 May 2019, 17:52), Manfred (15 May 2019, 03:10), modman (15 May 2019, 08:33), toneman (15 May 2019, 05:23), Zokk (15 May 2019, 22:17) and 3 more users
Bononoob
Have thanks: 19 times
Re: Eko - Multitone
Postby rockola » 15 May 2019, 13:48
Bononoob wrote:It has Wah (called Strepitoso in italian)
Eko gear has the best labels. I have an Eko Duke combo where the power switch is labeled SI/NO, inputs INGRESSI, and the tone controls ALTI and MEDI-BASSI :D
rockola
Has thanked: 13 times
Re: Eko - Multitone
Postby Ben N » 15 May 2019, 18:50
I have GOT to use this.
Ben N
Has thanked: 18 times
Have thanks: 14 times
Re: Eko - Multitone
Postby nightraven » 16 May 2019, 10:35
The first? It seems unusual for an Italian effects manufacturer to come up with something original...
Does this thing predate the Selmer Fuzz/wah/repeat? (c. 1969)
nightraven
TGP Refugee
Has thanked: 15 times
Have thanks: 61 times
Re: Eko - Multitone
Postby Dirk_Hendrik » 18 May 2019, 16:32
nightraven wrote:The first? It seems unusual for an Italian effects manufacturer to come up with something original...
Careful here. Italy had a very respectable industry of electronic musical instruments in the 70's and eigthies. Especially in the synthesizer arena they did cool stuff. Think brands like Crumar and Siel. Siel was taken over by Roland for production capacitywhen they lost the battle against the DX7 (and they weren't the only one) later which resulted in some very characteristic Siel design work showing up in Roland equipment.
Which means that it's not that hard to imagine some original effects technology can originate from Italy. Or perhaps be more known under another non-italian brandname.
For this message the author Dirk_Hendrik has received thanks:
OC26 (21 May 2019, 10:57)
Has thanked: 255 times
Have thanks: 1036 times
Re: Eko - Multitone
Postby idy » 20 May 2019, 18:10
Is that booster schematic right? very unusual...?
For this message the author idy has received thanks:
Bononoob (21 May 2019, 17:37)
idy
Has thanked: 31 times
Have thanks: 28 times
Re: Eko - Multitone
Postby Manfred » 21 May 2019, 11:52
idy wrote:Is that booster schematic right? very unusual...?
I cannot recognize any circuit principle.
Thought to myself, who knows and ran a circuit simulation, but the circuit was not working.
I think the circuit needs a review.
For this message the author Manfred has received thanks:
Manfred
Has thanked: 1051 times
Have thanks: 637 times
Re: Eko - Multitone
Postby Bononoob » 21 May 2019, 17:37
Oops looks like I swapped Input and Output. It makes sense if you read it the other way right ?
I corrected it, and ran it through a circuit simulation. You tell me if it still looks wrong (it's a weird boost anyway, lot of treble very quickly).
Thanks for the heads up
Bononoob
Re: Eko - Multitone
Postby Manfred » 22 May 2019, 13:16
The EKO booster circuit very similar to the VOX V8401 booster circuit.
I run the simulaton, using a BC183BP transistor that is a good replacement for the FS33805 transistor.
There is no significant gain, but a gain less then one namely from 0.14 to 0.91 depend on the potentiometer setting.
Thereby the input voltage was 50 Millivolts @ 1kHz.
Following the VOX booster circuity a changed the resitor values of the base voltage divider
form 22k to 220k and from 68k to 680k.
The circuit work now and have a gain form 1.4 to 8.6.
287m (22 May 2019, 14:00)
Manfred
Users browsing this forum: No registered users and 8 guests
