Univox - Superfuzz  [schematic]
Postby MoreCowbell » 09 Oct 2008, 18:59
Incredible - after searching "univox" , "super" + "fuzz", and "superfuzz" theres no thread on this classic effect.
Anyway, schematics can be found
MoreCowbell
Have thanks: 11 times
Re: Univox Superfuzz
Postby analogguru » 09 Oct 2008, 20:56
And here are the project files for your own clone:
http://members.fortunecity.com/uzzfay/home.html
you can choose between grey/black or orange/blue.
Have thanks: 116 times
Re: Univox - Superfuzz
Postby Bside2234 » 10 Oct 2008, 05:43
I am building one right now. I am 1 resistor short :evil:
I personally am really sick of fuzz pedals. I just had to build this one though.
Bside2234
Have thanks: 49 times
Postby Fuzzer » 10 Oct 2008, 07:20
I am sick of an addiction to fuzz pedals.
Fuzzer
Have thanks: 18 times
Postby Solidhex » 16 Oct 2008, 03:31
analogguru wrote:And here are the project files for your own clone:
Yeah,
There isn't a specific a specific schem given for grey black vs orange blue but you can see the early version has a .001 cap in the filter. The later ones have a .002. Pretty subtle difference though.
--Brad
For this message the author Solidhex has received thanks:
modman (12 Feb 2015, 09:18)
Solidhex
Has thanked: 10 times
Have thanks: 17 times
Postby ShortScaleMike » 17 Oct 2008, 11:21
I made designed and built a stripboard layout for this. the original layout is verified (it was a paper design), unfortunately this electronic version isn't as yet.
Here is the one I built:
Tones are footswitchable with a dual colour LED
ShortScaleMike
Has thanked: 19 times
Have thanks: 92 times
Postby Alex Frias » 17 Oct 2008, 13:19
The "STARVE" knob is some kind of SAG control?
Alex Frias
Have thanks: 13 times
Postby ShortScaleMike » 17 Oct 2008, 14:23
Yup
ShortScaleMike
Postby Kinki fuzz » 21 Oct 2008, 09:06
This piece of junk can destroy a man... uh! personal fauvorite!,
Well it has no mistery, there's plenty of info about it on the net, but I agree it deserved it's own topic.
Strongly recomended for every over-the-top-fuzz junkie.
Kinki fuzz
Has thanked: 18 times
Have thanks: 2 times
Postby salocin » 21 Oct 2008, 23:10
What does it sound like with the starve pot? Just about to case one of these, and might be interested in adding one in if it seems worthwhile.
salocin
Have thanks: 6 times
Postby Solidhex » 22 Oct 2008, 08:33
Yo
If you have an extra pot laying around I'd say do it. At first it just seems like a combo fuzz/volume control since it affects the volume and gain but the character of the fuzz gets less complex and gates in a cool way. It won't turn it into a fuzz factory or anything but its fun. Use a 5k though. The sound completely dies past that so a 10k or higher will have a large dead zone towards the end of the pot travel.
--Brad
Solidhex
Postby salocin » 22 Oct 2008, 10:15
Realised when I got home from work and started thinking about this that I had already drilled the enclosure for two pots (and also that I didn't have the right pot values so couldn't finish it tonight :cry: ). Lucky for me this build is for someone else so when I build one for myself I'll be sure to add this in. I'm quite a fan of gatey fuzzes.
salocin
Postby ShortScaleMike » 22 Oct 2008, 12:41
Solidhex wrote:Yo
--Brad
+1
Just play around - I happened to like it.
ShortScaleMike
Postby graemey » 23 Oct 2008, 21:23
Is the starve wired as a variable resistor that simulates a dead or dying battery? does it just starve the circuit of voltage?
I fancy attempting this one and will add a starve if I can. Great looking pictures by the way! :D
graemey
Postby RnFR » 23 Oct 2008, 21:36
here you go-
there is a lot of good info on beavis' site.
http://www.beavisaudio.com/Projects/DBS/
cheers!
Has thanked: 150 times
Have thanks: 174 times
Postby ShortScaleMike » 24 Oct 2008, 14:23
graemey wrote:Is the starve wired as a variable resistor that simulates a dead or dying battery? does it just starve the circuit of voltage?
Absolutely, just a pot inline with the voltage to the circuit.
ShortScaleMike
Postby graemey » 26 Oct 2008, 14:41
Great stuff, Im gonna get busy with this one real soon! Thanks. :D
graemey
Postby salocin » 30 Oct 2008, 04:14
To those of you who have built the superfuzz- do you have much trouble with hum/noise? Just finished mine off, and there's a fair amount of hum, which i've never had much trouble with in previous builds. I did have to twist the legs of the base and collector round as I used 2SC828's but the layout was designed for 2N2222's. Could that have anything to do with it?
For this message the author salocin has received thanks:
piedlilarvete (23 Feb 2013, 23:00)
salocin
Postby Solidhex » 30 Oct 2008, 09:56
With any Superfuzz build expect a delayed blast of hiss about a split second after you hit a note or chord. If you don't like it TOUGH!
--Brad
Solidhex
Postby salocin » 30 Oct 2008, 10:08
So glad to hear that! Have been trying to figure out what on earth I might've done wrong that would be causing that.
salocin
Next
