Dharma Sound - Sustainer
Postby MoreCowbell » 10 Nov 2008, 01:32
MoreCowbell
Have thanks: 11 times
Re: Dharma Sound - Sustainer
Postby RnFR » 10 Nov 2008, 06:30
i still think this is one of the coolest brand names from back in the days. it just has that psychedelic je ne c'est quois.
Has thanked: 150 times
Have thanks: 174 times
Postby DiscoFreq » 10 Nov 2008, 11:50
Shht, I'm bidding :p
I have this one, probably 100% the same:
http://filters.muziq.be/model/futuristicsounds/sustain
EffectsDatabase: http://www.effectsdatabase.com
22000 pedals, 4000 brands, 350 brand interviews
NAMM 2016: http://fxdb.org/namm
DiscoFreq
Have thanks: 25 times
Postby analogguru » 10 Nov 2008, 12:22
RnFR wrote:i still think this is one of the coolest brand names from back in the days. it just has that psychedelic je ne c'est quois.
I agree totally - also the artwork is very cool.
DiscoFreq wrote:I have this one, probably 100% the same:
:hmmm: time for pictures of the track side and some info on component values used - even when I doubt, that there will be a big schematic difference to the Roland AS-1 (and the Colorsound SupaSustain clone, of course).
Have thanks: 116 times
Postby DiscoFreq » 10 Nov 2008, 12:52
Ok, but it's one of those that I have to search for, I don't know in which box it is :D
I have a Roland AS-1 as well, maybe I can compare the pcb's :)
DiscoFreq
Postby analogguru » 10 Nov 2008, 13:00
The pcb-layout is completely different, but the schematics match - even when the colorsound made units use 1µF film capacitors instead of electrolytics.
I wonder if the futuristicsound (accidently) is wired for 9V ? should be 18V....
BTW, do you have a Colorsound Sustain Module ?
This is completely different, probably working with a FET (or transistor only?) - I like to see the track side for a very long time.... :roll: :wink:
Postby DiscoFreq » 10 Nov 2008, 23:51
analogguru wrote:The pcb-layout is completely different, but the schematics match - even when the colorsound made units use 1µF film capacitors instead of electrolytics.
No, but I do have a Eurotec Black Box Sustain Module I think (not 100% sure which Eurotec pedals I have ;))
DiscoFreq
Postby analogguru » 11 Nov 2008, 01:02
From the time of appearance I would assume that the Eurotec is similar or identical to this Orange/Dharma Sound/Colorsound Sustain.
Postby Professor SourTone » 14 Apr 2011, 11:28
Just arrived - I like it a lot. Sustains very nicely and not too brutal as a compressor - I don't like "black hole" compressors.
The box is very sturdy, and smaller than you'd think. It has an old-school boutique character.
I also have the Roland AS-1 (and a Supa Sustain), it has to be nearly the same circuit as they do sound similar.
For this message the author Professor SourTone has received thanks: 2
modman (09 Dec 2015, 18:52), Steven_M (15 Apr 2011, 19:21)
Professor SourTone
Have thanks: 40 times
Postby Professor SourTone » 14 Apr 2011, 11:32
It also looks to be an identical layout to DiscoFreq's Futuristic Sounds
http://www.effectsdatabase.com/model/fu ... ds/sustain
modman (09 Dec 2015, 18:57)
Professor SourTone
Postby DiscoFreq » 14 Apr 2011, 12:46
I have the Futuristic Sounds Sustain myself :D
I was bidding on this one too, but my snipe bid was too low :(
DiscoFreq
Postby uncleboko » 15 Apr 2011, 23:17
Larry Macari!!
uncleboko
Has thanked: 55 times
Have thanks: 18 times
Postby Professor SourTone » 09 Dec 2015, 13:42
Do you still need the sustain module guts?
modman (09 Dec 2015, 18:56)
Professor SourTone
Postby Professor SourTone » 09 Dec 2015, 13:44
Professor SourTone
Postby Professor SourTone » 09 Dec 2015, 14:57
Professor SourTone
