Eko - Multitone
Eko - Multitone
Postby analogguru » 17 Sep 2007, 16:08
One of the first pedals which I traced in the 70´s was the Eko Multitone. A monsterwork cause it was the first "multieffect". Here are the first sharp hires-guts from this pedal:
http://cgi.ebay.com/Vintage-Eko-Multito ... dZViewItem
Have thanks: 113 times
Postby modman » 17 Sep 2007, 17:37
Wow, great stuff, 18V: ok, but what about the two pots ?
How much is the Aussie Dollar? Might be tempted.
edit: sorry, : "and when the wah is turned off the expression pedal becomes a volume pedal" hence the double pot
Has thanked: 2950 times
Have thanks: 519 times
Re: Eko - Multitone
Postby Chugs » 28 Apr 2010, 07:55
Here's another Multitone on ebay. Large guts shots at the bottom of the listing. Looks like it has been modified for true bypass.
http://cgi.ebay.co.uk/vintage-1973-EKO- ... 684wt_1083
Chugs
Has thanked: 53 times
Have thanks: 47 times
Re: Eko - Multitone
Postby analogguru » 28 Apr 2010, 08:31
This unit is true bybass from the factory, but the switches have been replaced, the electrolytics and probably one potentiometer too.
Re: Eko - Multitone
Postby zxspex » 22 May 2017, 07:37
Found this on a local listing. Admittedly not the best photo but I couldn't find the schematic elsewhere.
For this message the author zxspex has received thanks: 4
d312a (22 May 2017, 19:31), Dirk_Hendrik (24 May 2017, 18:29), emilpaulsrud (22 May 2017, 10:22), Nocentelli (25 May 2017, 21:50)
zxspex
Have thanks: 4 times
Re: Eko - Multitone
Postby Nocentelli » 25 May 2017, 21:50
The repeat percussion derivative module has a diode facing the collector of the audio stage transistor i haven't seen before - could it serve a useful purpose, e.g. reducing tick?
mmolteratx wrote:absolutely zero commercial use allowed. If I find anyone selling these, I'll fly to your house and kick you in the nads. And you may or may not find yourself in trouble.
Nocentelli
Has thanked: 807 times
Have thanks: 814 times
Re: Eko - Multitone
Postby mictester » 26 May 2017, 00:14
Nocentelli wrote:The repeat percussion derivative module has a diode facing the collector of the audio stage transistor i haven't seen before - could it serve a useful purpose, e.g. reducing tick?
The diode is being used as a current-controlled attenuator. Look up "diode attenuator" to see what they're doing. It's nothing at all to do with "ticking"
For this message the author mictester has received thanks:
Nocentelli (26 May 2017, 06:33)
mictester
Has thanked: 32 times
Have thanks: 784 times
Users browsing this forum: Bing [Bot], toneman and 3 guests
