Vox - Wah Wah Distortion  [schematic]
Postby Rocket Roll » 19 Jun 2009, 13:39
VOX Wah-Wah Distortion on DiscoFreq: http://www.effectsdatabase.com/model/vo ... distortion
Any idea which kind of inductor, what pots, what kind of integrated fuzz and where it was built?
Transistors: 2xBC209C and 2xFMPS5172.
Rocket Roll
Have thanks: 27 times
Re: VOX Wah-Wah Distortion (Italy? USA? What inductor?)
Postby Rocket Roll » 19 Jun 2009, 13:41
Some more gutshots:
Rocket Roll
Postby Rocket Roll » 19 Jun 2009, 13:43
...and some more:
Rocket Roll
Postby Paul Marossy » 19 Jun 2009, 14:27
Huh, I've never seen one of those. The inductor doesn't look like any I've seen before.
Can you draw up a schematic for it? That's probably the only way anyone is going to determine what the fuzz section looks like, and if it is original or a derivative of something else.
Paul Marossy
Have thanks: 4 times
Postby lolbou » 19 Jun 2009, 14:34
I guess it's a fairly basic inductor with a green plastic cover on it. I guess that removing the nut on top of it would let the green plastic come free, and it would look like this (on the right):
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
lolbou
Has thanked: 347 times
Have thanks: 240 times
Postby Paul Marossy » 19 Jun 2009, 14:42
Yeah, I doubt that the inductor is anything special.
Paul Marossy
Postby ik6gpy » 19 Jun 2009, 14:59
That is probably an italian pedal. I had a Moreschi Wah-Fuzz (nothing special) that had the same enclosure and the same inductor of your Vox. Bc209's are european trannies, so my guess is probably right.
ik6gpy
Has thanked: 34 times
Have thanks: 25 times
Postby Paul Marossy » 19 Jun 2009, 15:41
ik6gpy wrote:That is probably an italian pedal. I had a Moreschi Wah-Fuzz (nothing special) that had the same enclosure and the same inductor of your Vox. Bc209's are european trannies, so my guess is probably right.
My first thought was that it is a Italian Jen made product. But on regular wah pedals, that is usually clearly marked... :hmmm:
Paul Marossy
Postby Rocket Roll » 19 Jun 2009, 16:34
I found that it looks surprisingly similar to Silversound SE-20 Whau-Whau Distortion - same type of build, I'd say even the same factory.
Here's the schematics and some pics of the SE-20: http://www.fetishguitars.com/mrt/silversound/jean.html
Rocket Roll
Postby Paul Marossy » 19 Jun 2009, 17:34
Rocket Roll wrote:I found that it looks surprisingly similar to Silversound SE-20 Whau-Whau Distortion - same type of build, I'd say even the same factory.
Yeah, the two look very similar.
Paul Marossy
Postby ik6gpy » 19 Jun 2009, 18:21
Here it is: http://www.effectsdatabase.com/model/cosmosound/cse3
It was made by the old italian Cosmosound factory. It's exactly the same pedal of yours.
ik6gpy
Postby Paul Marossy » 19 Jun 2009, 18:34
ik6gpy wrote:Here it is: http://www.effectsdatabase.com/model/cosmosound/cse3
Looks like a dead ringer!
Paul Marossy
Postby Rocket Roll » 19 Jun 2009, 22:18
Yep, that's the one!
Do you think it's possible for it to be a... what's the word... a forgery? "Vintage fogery", but still a forgery? Not an official VOX product? Something that was made with a VOX logo in order to boost the sales?
Rocket Roll
Postby DiscoFreq » 20 Jun 2009, 12:37
I have 2 of these: 1 Vox, 1 Cosmosound :D
EffectsDatabase: http://www.effectsdatabase.com
22000 pedals, 4000 brands, 350 brand interviews
NAMM 2016: http://fxdb.org/namm
DiscoFreq
Re: Vox - Wah Wah Distortion
Postby noelyoung » 02 Mar 2010, 12:32
I have a Silversound SE-20, and it's the same pedal, like this Vox and Cosmosound. Can someone tell me the taper of the original pot? I have to replace because it's scratchy. Thanks
noelyoung
Postby Rocket Roll » 30 Nov 2014, 15:21
I have another one in front of me. Since they're so few and far between in our parts, a few more photos, including the PCB traces:
Rocket Roll
Postby Rocket Roll » 30 Nov 2014, 15:23
...more elements...
Rocket Roll
Postby Rocket Roll » 30 Nov 2014, 15:29
...and PCB.
I like this fuzz. For me, the best vintage Si Fuzz Face that I have ever tried. Cleans very well (extremely well for a Si FF), has a great wall of thick but very musical fuzz, "sharpens" the guitar nicely when you roll off the pickup volume.
As far as I can tell, the fuzz part uses two MPS5172 transistors, and the wah uses two BC209C transistors. It stands to reason, since MPS5172's should have lower hFE (from 150 upwards). However, not a lot of silicone Fuzz Faces use them.
The only problem? A decent amount of hiss. Wouldn't know if that has something to do with the layout, this particular unit or a part that has "drifted".
Rocket Roll
Re: Vox - Wah Wah Distortion  [schematic]
Postby Rocket Roll » 30 Nov 2014, 17:33
So, here we have the fuzz part of the circuit (minus Volume and Fuzz pots and 10uF capacitor mounted on the Fuzz pot), and the schematic. I have modified the Cosmosound Distortion Whau Repeat schematic that you can find on the Effectsdatabase (http://files.effectsdatabase.com/docs/s ... ematic.gif). The values are mostly OK, but the author of that one had a different unit or made a mistake: R2 is 27K and R5 is 2K7 in the VOX, as all of the pictures clearly show.
I cannot check the potentiometers' value, but I expect no problems there.
So, not your typical silicone Fuzz Face, but a variant.
For this message the author Rocket Roll has received thanks: 2
D-Day (30 Nov 2014, 20:26), jag775 (21 Dec 2015, 15:41)
Rocket Roll
Postby ljn » 30 Nov 2014, 17:49
Wow! That's an awesome looking pedal. As for the scratchy pot, have you tried some contact cleaner?
Education is 10% knowledge and 90% brainwashing. We're only told what they want us to know. The rest is fabrication in it's purest form.
ljn
Have thanks: 8 times
Next
Users browsing this forum: magradacuc and 14 guests
