Top Gear - Sound Rotator
Postby borislavgajic » 05 Jun 2008, 20:08
not very clear pictures,but...... :wink:
For this message the author borislavgajic has received thanks: 3
dv8r601 (21 Jun 2018, 22:07), modman (01 Jun 2018, 08:00), pinkjimiphoton (23 Jun 2018, 23:16)
borislavgajic
Has thanked: 140 times
Have thanks: 249 times
Re: TOP GEAR sound rotator ...guts
Postby MoreCowbell » 06 Jun 2008, 02:27
I dig the old stripboard layout. I wish the pics were more clear, but I'm sure it was a PITA to get pictures of a rare old unit like that in the first place....
Thanks... :D
MoreCowbell
Have thanks: 11 times
Postby Bernardduur » 06 Jun 2008, 09:50
Wow..... that looks really nice...... what does it do? I "guess" chorus and tremolo????
Some better pics here although they won't add much :)
Bernardduur
Has thanked: 87 times
Have thanks: 483 times
Postby borislavgajic » 06 Jun 2008, 10:26
it has 4 ldr's ...placed around light bulb........so it is IMHO transistor vibrato..or phaser... :D
it sounded very dull and muddy ...
I had it for one day only ..long enaugh to take photos....
:horsey:
http://www.harpamps.com/schematics/univibe.pdf
borislavgajic
Postby DiscoFreq » 06 Jun 2008, 10:38
EffectsDatabase: http://www.effectsdatabase.com
22000 pedals, 4000 brands, 350 brand interviews
NAMM 2016: http://fxdb.org/namm
DiscoFreq
Have thanks: 25 times
Postby borislavgajic » 28 Mar 2009, 16:38
I could get to this pedal again........so is somebody interested to trace this .....and to help me fixing it......sound was not sharp (clear)........bad capacitors??? something else......
if there is any interest,I will get to it :thumbsup
boris
borislavgajic
Re: Top Gear - Sound Rotator
Postby Professor SourTone » 30 May 2018, 12:10
borislavgajic wrote:I could get to this pedal again........so is somebody interested to trace this .....and to help me fixing it......sound was not sharp (clear)........bad capacitors??? something else......
boris
Boris - its possible I now own this pedal, as it came to me from Serbia - is there a schematic anywhere?
Professor SourTone
Have thanks: 42 times
Postby Professor SourTone » 21 Jun 2018, 18:28
It is now being looked at - lots of things wrong with it, bad photocell, oscillator, transformer buzz. Wet still very dull and wet/dry not "summing", whatever that means. It will sound very different when fixed, I suspect. H
Professor SourTone
Postby Professor SourTone » 24 Jun 2018, 23:12
Professor SourTone
Re: Top Gear - Sound Rotator *now with circuit*
Postby Professor SourTone » 25 Jun 2018, 17:08
Herewith circuit diagram + post-fix gutshots by Dan Coggins of Dinosaural, although he stresses that without rebuilding it, the oscillator section may not be 100% correct.
It had a dead RPY58A photoresistor (replaced with ORP12, similar functionally), oscillator needed tuning, lube trimpots, fix buzzing transformer, dry joint on level pot.
One mod, 22k "straight blend" mod resistor across bypass switch to brighten it up. Buffer recommended as input impedance very low.
https://flic.kr/s/aHsmi83jTG
Its not arrived home yet, but the IG link in my previous post suggest its a changed beast!
For this message the author Professor SourTone has received thanks: 4
borislavgajic (26 Jun 2018, 21:30), dv8r601 (25 Jun 2018, 22:53), Nocentelli (27 Jun 2018, 11:25), uncleboko (25 Jun 2018, 17:14)
Professor SourTone
Postby Zokk » 26 Jun 2018, 08:43
Hi, please could you post the pictures on another media: both links don't work for me.
Thanks.
Zokk
Has thanked: 176 times
Have thanks: 61 times
Postby Scruffie » 26 Jun 2018, 10:19
And here I was thinking it was just going to turn out to be another UniVibe, that actually looks interesting, seems it's just a transistor based version of the later 'Rotator'. I'll be interested to hear how it sounds, I can't quite picture it.
Scruffie
Has thanked: 27 times
Have thanks: 139 times
Postby Nocentelli » 26 Jun 2018, 15:16
Scruffie wrote:interested to hear how it sounds, I can't quite picture it.
I'm also intrigued. If you can't see the flickr schematic, it's like four colorsound inductor-less twin-T wah circuits in parallel but all tuned to different bands, and all modulated by a (PSO?) LFO. I am going to type thing out with a LED instead of the lamp.
borislavgajic (26 Jun 2018, 21:31)
Nocentelli
Has thanked: 863 times
Have thanks: 837 times
Postby Professor SourTone » 26 Jun 2018, 22:38
Zokk wrote:Hi, please could you post the pictures on another media: both links don't work for me.
Thanks.
I will have a go - what’s the recommended way nowadays, photobucket is hopeless now.
Professor SourTone
Postby Professor SourTone » 26 Jun 2018, 22:41
This from Dan - “A view of the audio filter board. There are four summed (parallel) band-pass filters using Wien-bridge networks, whose frequency bands are roughly an octave apart and each are adjusted to be on the threshold of resonance using individual trimpots. The four of these single transistor stages added together provides four deep notches that sweep up and down together and carve out the input signal. The additional resistor provides more straight signal bandwidth for these to cancel agains @Level=8.”
Professor SourTone
Postby Zokk » 27 Jun 2018, 08:33
Professor SourTone wrote:I will have a go - what’s the recommended way nowadays, photobucket is hopeless now.
Thanks, you can upload the pictures directly on the forum, check the tab below when you write a message :"upload attachment".
For this message the author Zokk has received thanks:
Zokk
Postby Professor SourTone » 24 Aug 2018, 20:05
Sorry delay
For this message the author Professor SourTone has received thanks: 2
snk (03 Nov 2018, 09:50), Zokk (24 Aug 2018, 21:59)
Professor SourTone
Postby EddieTavares » 25 Aug 2018, 00:46
How does it sound?
EddieTavares
Have thanks: 13 times
