Ibanez - Double Sound Fuzz Wah [schematic]
- Dirk_Hendrik
No Fuzzface for the fuzzsection this time. The wah part is very standard though.
ere ye go,
Ibanez Double Sound schematic
ere ye go,
- analogguru
Could it be that R11 is 47k ?
And there is really no additional 1M at the gate of T2 ?
BTW, the footswitch SW1 appears to be replaced in your unit. Originally it is a 2PDT swich, the same as SW-2.
- Dirk_Hendrik
again.. changed. While attempting to avoid these kind of remarks I do thank you for keeping me sharper.analogguru wrote: Could it be that R11 is 47k ?
Checked, checked and doublechecked since I already expected a (justified AG ) for that.analogguru wrote: And there is really no additional 1M at the gate of T2 ?
Nope. It's not there.
I don't have a reason to believe this to be the case while I do for SW2 where secondary soldering seems to be in place. If so, it's done by someone who does know his soldering skills very well.analogguru wrote: BTW, the footswitch SW1 appears to be replaced in your unit. Originally it is a 2PDT swich, the same as SW-2.
And for those who consider (some) of the above asskissing or whatever they want to call it, Too bad. I do consider AG one of the better teachers in critical focus on details and thank him for that.
- lolbou
No asskicking whatsoever to me, but I must admit that I have thought: how come can he (AG) compare/analyse a schem that fast?!Dirk_Hendrik wrote:And for those who consider (some) of the above asskissing or whatever they want to call it
But yes, AG's knowledge is amazing, and his sharing is so cool...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
- analogguru
The answer is simple:lolbou wrote:No asskicking whatsoever to me, but I must admit that I have thought: how come can he (AG) compare/analyse a schem that fast?!Dirk_Hendrik wrote:And for those who consider (some) of the above asskissing or whatever they want to call it
with a huge picture collection.
And this picture collection shows a 2PDT for S1 in all cases. BTW, I havent seen 4PST used in japanese boxes originally. They were common in european pedals like from Schaller.
- lolbou
And a good sight, not like mine challenged with colorblindness... It would take me a lot of zooming on the second picture to actually compute a resistor value...
I have to use a magnifier and a bright lamp to make difficult readings on the resistors...
Anyway, thanks to both of you for info and schematic about this unit...
- analogguru
Don´t bother, I couldn´t do this too from the second picture (alone). I used the picture below, but even with this I was not 100% sure about it. Therefore my question to Dirk.lolbou wrote:And a good sight, not like mine challenged with colorblindness... It would take me a lot of zooming on the second picture to actually compute a resistor value...
- Greg
I'm colourblind too... sucks doesn't it ?lolbou wrote:And a good sight, not like mine challenged with colorblindness... It would take me a lot of zooming on the second picture to actually compute a resistor value...
I can sometime read them with a magnifier in good light.. otherwise i have to measure or get my son to tell me what it is..
- RnFR
i wonder-
would JFETs have to be picked for tolerance at the factory for this circuit? you would think that there would be a large amount of variation between boxes if they didn't do some kind of sorting.
- Brainbender
thanxxxxx!!!!
Hi Dirk,
thanks for the schematic and the layout of the Double Fuzz.
But, I´m a little confused:
in the schematic the 2,2 electrolyt-cap on "out" (balance-pot) is with pos. to SK30 - in the layout (https://www.freestompboxes.org/viewtopic.php?f=13&t=6994) the cap is with neg. to the pot?
Is the schematic right?
- Dirk_Hendrik
Thanks for poining that out.
The layout is the correct one. The schem is wrong on that location.
- sinner
- Has thanked: 1031 times
- Been thanked: 909 times
How about R8? Is it 27k as in schemo, or 47k as in layout?
- borislavgajic
- Opamp Operator
- Has thanked: 131 times
- Been thanked: 277 times
Please can somebody post nice shot of wiring .....secound wersion with LED....please
thanks
Boris
thanks
Boris
- borislavgajic
- Opamp Operator
- borislavgajic
- Opamp Operator
You are missing inductor for wah....rest should be easy......do you have pots and switches? box?
