Sola Sound - Tonebender MkIII [schematic]
- Electric Warrior
Numbers without units always cause lots of confusion. 0.19mA/190µA does sound like a nice amount of leakage.
- sinner
- Has thanked: 1031 times
- Been thanked: 909 times
My bad
- nooneknows
Since I 'don't like positive ground and charge pump and I wanted a normal power supply still using a PNP do you think this partial redraw of the schematic could work? (the sound comes from the last tranny the most, so I just flipped the germanium PNP)
thank you!
thank you!
- tonebenderNPNandPNP.jpg (48.24 KiB) Viewed 3302 times
KindaFuzzy wrote:Thanks man, collector voltages are as follows with respect to 9v+:
Q1 -3.5v
Q2 -3.5v
Q3 -1.9v (depending on the time of day and rotation of the moon, it's very sensitive)
Since the supply voltage to Q3's collector is ~4.5v, I was aiming for about half, and found that negative 1.5v-2.0v sounded best to my ears.
Thank you thank you thank you! I have been building a few tone benders ove the last few years and have never been totally happy with them. This is because I have been making the collector voltage to -4.5V. After seeing this post I tried a 33k and a 10k trim and got the collector voltage on Q3 down to 1.9V! Woo Hoo! This is the shit I've been looking for.!! I will be modifying all theTBs I have built to this. It sounds the bomb!
Great tip. I'm so happy
- LucifersTrip
- my favorite amplifier: Companion Psychedelic Machine
- Completed builds: Mosrite Fuzzrite (Si), Mosrite Fuzzrite (Ge)[2], Get Lo-Fi Fuzz, Fuzz Face (Ge) [2], Fuzz Face (Si) [3], Mos-Face, Vox Tone Bender, Kay Tremolo, Os Mutantes Fuzz [2], Psychedelic Fuzz, Smokey Amp, Sunn Buzz, Jen Fuzz, Fancy Fuzzbox, Muff Fuzz (op amp) [2], Buzz Box, Fuzz King, Rangemaster [5], Maestro FZ - 2/3, Ruby Amp, Orpheum Fuzz (Ge) [4], Great Destroyer, Schizo, Carlsbro Suzz, Shin-Ei Companion Fuzz (si), DOD 250 Gray [2], Super Dirt Fuzz, Fuzz Factory, Jordan Boss Tone, Sam Ash Fuzzz Boxx, Heathkit TA-28 Fuzz, Olson New Sound Fuzz, LRE Fuzz Sound, Green Ringer, Vox Super Beatle (Ge), Colorsound One Knob (Ge), Demon Buzzz [2], Demon Wasp v1, Demon Wasp v2, Super Hard-On, Bazz Fuss, Burns Buzzaround [2], Selmer Buzztone, Shin-Ei Companion Fuzz (Ge), Fuzz Face/FY-2 (Ge), Zonk Machine, Univox Squarewave, Demon Fuzzz, Mosrite Fuzzrite BG-500/1000 (Ge), Univox Superfuzz, Marshall Supa Fuzz, Demon Monster, AA Overdrive/ Retro Fuzz, Tone Bender MKII, Psychtar, Jordan Vica Vibe, etc...
- Has thanked: 19 times
- Been thanked: 71 times
- Contact:
I found an easy way to trim is to turn the tone to full bass, then use that trim on Q3 to set the max bass you want. and yes, for me it's usually in the 2-3V range. you don't have to worry about the treble side since it always has more than enough.
- Mbas974
Hi, I try to figure out the classic layout of mkIII
but i get mess in 220p cap zone....
Can anyone post the image or the link to to be back of original PCB (or any similar....)
thanks
thanks
- mkIII.jpg (55.43 KiB) Viewed 3075 times
Just a noob here but its like one of the games I played on my daughter's tablet.
On the suggested layout, if you delete the blue line with pink dots, replace the orange line with the light blue, and put in the green line, it should do what I think you are after?
I hope the picture is attached - first time attempt
- mkIII-1.JPG (53.63 KiB) Viewed 3068 times
- Mbas974
Yes, that's a way... and I thank you for that.
What I'd like to check is the orginal design solution ( maybe the same maybe not ).
So if anyone has the image of the PCB... i will appreciate it.
- sinner
Was it something wrong with mine?
- sinner
Nufin'
- sinner
Status LED is ussualy off the signal patch
Wont affect the sound at all
- Mbas974
Ok, buit it and it sound very good.
But I'm wondering about C5 Value (Q2 source cap)...
I bought GE Transistors from smallbear (very good quality and service !!) and into his schematic it is 22uF while in every schematic I see it is 10uF (or less)
Any comment is appreciated.
- sinner
Q2 source cap?
- Mbas974
Yes.
I get the answer directly from smallbear support mail (very efficient and gentle !!) :
" The capacitor C5 has be to be large enough to sink all audio frequency to ground. 10 mf. is enough but a 22 mf. cap will not effect the performance either "
The pedal I built sund amazing ! thanks to all.
- sinner
Actualy it will. And it's emitter bypass cap not Q2 source cap
