BK Butler - Tube Driver  [schematic]
Postby Tubedriver » 08 Jan 2010, 18:12
I have both a 80s BK garage made Tubedriver and his latest reissue. After trying countless tubes I have discovered the NOS Telefunken ECC81 to give the best results. I have 3 of these tubes and they are extremely consistent providing great tone, mojo, and character to these pedals. To my ears the difference is astounding in both pedals. Yes, they are expensive but do not disappoint. Has anyone else discovered the same result?
"The only thing worse than bad guitar players playing good pedals, is bad guitar players playing bad pedals" -Tubedriver
Tubedriver
Have thanks: 6 times
Re: BK Tubedriver tube
Postby ik6gpy » 08 Jan 2010, 18:33
On the new Tube Drivers, both David Gilmour and Eric Johnson use Ei Yugoslavia Ecc83's. These tubes are made with the same specs as the old Telefunken Ecc83 flat plate. So i'm not suprised if you get the best results with that tube, even if it's an Ecc81. Right now on my clone i use a 1960 Nos General Electrics 12AU7, and i found it far superior to all the 12ax7 tubes that i've tried.
Ecc81 tubes give the pedal a Booster/Distortion flavor with a better balanced tone, on the other hand Ecc83/12ax7 gives the pedal a Distortion/Fuzz character.
To me 12au7/ecc81 is the way to go with this pedals. :thumbsup
ik6gpy
Has thanked: 34 times
Have thanks: 25 times
Postby theehman » 08 Jan 2010, 18:53
Tubedriver wrote:I have both a 80s BK garage made Tubedriver and his latest reissue.
Do you have pics of the "garage made Tubedriver"?
Ron Neely II
fx schematics and repairs
theehman
Has thanked: 81 times
Have thanks: 85 times
Postby Tubedriver » 08 Jan 2010, 19:05
Here you go.
For this message the author Tubedriver has received thanks:
modman (04 Apr 2015, 20:27)
Tubedriver
Postby theehman » 08 Jan 2010, 19:09
I thought you were talking about one of these:
They use 6AV6/6AT6 tubes
Ron Neely II
For this message the author theehman has received thanks:
theehman
Postby theehman » 08 Jan 2010, 19:20
That's one of the earliest models of the Tube Driver. Made around 1979.
Ron Neely II
theehman
Postby Tubedriver » 08 Jan 2010, 19:24
How does it sound compared to the 12AX version?
Tubedriver
Postby theehman » 08 Jan 2010, 19:30
Tubedriver wrote:How does it sound compared to the 12AX version?
It's really different. The 6AV6 is basically half of a 12AX7. It also has an optically controlled circuit with a Vactrol. I don't play guitar much but my friend has tried it out and was able to get very Eric Johnson-ish tones out of it w/ his strat.
Ron Neely II
theehman
Postby Tubedriver » 08 Jan 2010, 19:38
Cool, that must be his early kitchen table made version, just kidding.
To be honest I prefer BK's reissues to the originals. Provided the TF ECC81 is in. I find the RI to be smoother and more violin like. The originals are a tad noisier, but with more attitude.
Tubedriver
Postby Tubedriver » 08 Jan 2010, 20:53
Someone wanted detailed cap and pot values of my Tubedriver, so here goes:
There's only 1 cap on the trace side, it's a 473uF, 100v. 4 of these are on the component side and 1 on the trace side (Hence the label indicating 5 ea). I listed only one 473uF, 100v on the component side, all others on this side not labeled are these type. The only other chiclett style cap on the component side is a 103K, 100v and is labeled as such.
Audio taper pots - Drive 500k, LO 100k, HI 500k, Output 100k.
Cap list
1 ea, 450uF, 24v, silver
2 ea, 470uF, 16v, silver
1 ea, 220uF, 25V, blue
5 ea, 473k, 100v, Yellow chiclett style, one on the trace side, 4 on the component side
1 ea, 103k, 100v, Yellow chiclett style on component side
1 ea, .1uF, 100v, orange
1 ea, 331, brown disk type
1 ea, 41, brown disk type
2 ea, 4.7uF, 25v
That's all 15 caps
Tubedriver
Tubedriver cap and pot values
Postby Tubedriver » 08 Jan 2010, 21:07
Cap list
2 ea, 4.7uF, 25v
That's all 15 caps
For this message the author Tubedriver has received thanks: 2
modman (04 Apr 2015, 20:28), pete_el34 (15 Dec 2011, 16:15)
Tubedriver
Re: Tubedriver cap and pot values
Postby RnFR » 08 Jan 2010, 21:56
let's try to keep all this info together ok? :wink:
Has thanked: 150 times
Have thanks: 174 times
BK Tubedriver Resistor layout and values
Postby Tubedriver » 08 Jan 2010, 22:40
Here's the resistor layout and values.
Tubedriver
Re: BK Butler - Tube Driver
Postby pf_fan » 08 Jan 2010, 23:10
Here's something that can be useful for you, guys. I got this from Tube Works as a schematic of their 911 pedal. But looks like it originally was a schematic of the Tube Driver from 1986 done by Mr. Butler himself. Then someone modified it to match with the 911 pedal. Maybe it's a correct schematic for the pedal being analysed here?
For this message the author pf_fan has received thanks: 2
claire1321 (30 Aug 2011, 23:50), pete_el34 (15 Dec 2011, 16:16)
pf_fan
Have thanks: 5 times
Postby MWichni » 09 Jan 2010, 09:47
Hi, could you draw on the picture showing where are going traces under resistors?
Like this, but I'm not sure is it correct.
MWichni
Have thanks: 56 times
Postby Tubedriver » 09 Jan 2010, 20:31
Nope. I've e-mailed closeups with corrections.
Thx,
Tubedriver
Postby pete_el34 » 15 Dec 2011, 16:14
Hi all!
My first post here. :)
Did anybody made a schematic out of the 80s Tube driver being analyzed here?
Is it actually different from the Baja schematic of the BK Butler TD re-issue?
Thanks a lot,
Pete
pete_el34
Postby electrosonic » 16 Dec 2011, 09:12
I bought the Chandler version in the late 80s - it is this version...
Check out the bypass, the circuit is connected to the signal chain even when bypassed.
http://analogguru.an.ohost.de/193/schematics/Chandler_TubeDriver.gif
Andrew.
electrosonic
Has thanked: 28 times
Have thanks: 19 times
Postby pete_el34 » 16 Dec 2011, 16:29
electrosonic wrote:I bought the Chandler version in the late 80s - it is this version...
Andrew.
Hi All,
This schematic is for the chandler wall mart version (the one that doesn't say BK Butler on the enclosure).
Yes the TD is always loading the guitar, and the worst is that the bypass signal is not even picked up after the buffer.
Tubedriver wrote:I never saw one. Sorry
As soon as i have time i will trace this one from the pictures.
Curious to see what are the differences between the early and new ones.
pete_el34
Postby pete_el34 » 02 Jan 2012, 20:49
Hi all!
I looked at the pics today and i'm almost done with the schematic.
It has significant differences compared to the reissue version (tone stack, plate resistors, ..).
Can you please take more clear pictures around the opamp (trace side).
Sometimes is really hard to follow the tracks.
Also you missed to label one capacitor, it's hidden behind the gain pot. What's it's value?
There's a section above the opamp you labeled 3 resistors as being 680Ohm, it looks like only one is 680 and the other two are 6,8k. Can you confirm that?
Can you take clear picture for me of this zone of the PCB? If you can please take as many pictures as possible!
I need to clearly understand where those tracks below the resistors go!
Thanks for your help!
pete_el34
Next
Users browsing this forum: Exabot [Bot] and 22 guests
