BK Butler - Tube Driver  [schematic]
Re: BK Butler - Tube Driver
Postby Bernardduur » 28 May 2015, 19:07
Whaha, true!
For this message the author Bernardduur has received thanks:
Intripped (28 May 2015, 22:28)
Bernardduur
Has thanked: 87 times
Have thanks: 483 times
Postby tictac » 29 May 2015, 03:24
Does anyone know about the "Bias Control" that's available as a new feature? According to Butler it controls the amount of current draw of the cathode.... You're supposed to be able to dial in the bias for different tube types....
Seems like it would be easy enough to implement... a pot between the cathode and V- perhaps? :hmmm:
TT
tictac
Have thanks: 10 times
Postby tictac » 29 May 2015, 03:40
:oops: sorry for not doing a search first.... yep, it's a pot, Bajaman already drew up a nice schematic...
Funny cause I'm tinkering with my Bajaman tube driver after reading this thread just didnt realise he made some updates to the circuit... :slap:
TT
tictac
Postby teemuk » 29 May 2015, 17:07
tictac wrote:Does anyone know about the "Bias Control" that's available as a new feature?
In older TubeWorks units (e.g RT-902 Real Tube Rack) the "Bias" control was simply a potentiometer wired as variable cathode resistor.
teemuk
Have thanks: 53 times
Postby teemuk » 29 May 2015, 17:11
...oh, forgot to mention, quoted as being a feature that actually makes the distortion more tweakable and versatile.
http://music-electronics-forum.com/atta ... e-rack.jpg
teemuk
Postby whopperplate » 27 May 2018, 06:09
Thank you all for the wealth of info. I am working out the details for building one of these guys and I am I seeing correctly that only the hot is connected to the output jack, no ground? Is it connected via the input jack ground to chassis?
Another question, what would the effects be of increasing the drive and high pots from 500k to 1M? Some of the old pedals had this value and I am wondering about their tonal difference.
Thank you for the time!
Charlie
whopperplate
Postby Dirk_Hendrik » 27 May 2018, 07:43
Drive: Even more gain. About double of the max you had with a 500k pot. Tone: You'll change the frequency characteristic of the tone stack.
Has thanked: 253 times
Have thanks: 1014 times
Postby whopperplate » 27 May 2018, 12:21
Dirk_Hendrik wrote:Drive: Even more gain. About double of the max you had with a 500k pot. Tone: You'll change the frequency characteristic of the tone stack.
Awesome, that’s what I was assuming more or less, thank you!
Does it shift the frequency response up or down? I have never been educated on the math of what’s going on. I appreciate all the help, thank you so much.
Charlie
whopperplate
Postby whopperplate » 28 May 2018, 04:53
Still most curious about the grounding scheme
whopperplate
Postby whopperplate » 28 May 2018, 16:24
Also from looking at the PCB photos it seems the red LED is wired with the cLED to ground after , rather then between the R16 and the LED as written in the schematic. can anyone please also confirm this? Thank you
Charlie
whopperplate
Previous
