EH Echoflanger  [schematic]
Re: EH Echoflanger
Postby Govmnt_Lacky » 06 Apr 2012, 20:17
nelson wrote:This thing is a bitch to route.
Just a friendly suggestion 8)
You really do not need all that real estate for the 2P4T rotary switch. You can pick up GND anywhere and you only need 3 connection points for the contacts.
You could probably buy yourself quite a bit more space if you don't incorporate an "on-board" rotary switch :applause:
Govmnt_Lacky
Have thanks: 45 times
Re: EH Echoflanger
Postby nelson » 07 Apr 2012, 01:49
After I posted this I dumped the rotary switch and 4053 in favour of an SPDT toggle for the disconnecting the LFO and switching to A steady DC and a 3PDT toggle for the other changes in the audio path and the clock cap. I ended up replacing the blend switch with a full wet/dry blend pot and added a gain recovery stage at the output. All 4 functions work as they did before. Just two toggles instead of one rotary and those two CD4053.
The Electronic switching and rotary just felt like a bigger headache than I wanted.
nelson
Have thanks: 9 times
Re: EH Echoflanger
Postby Govmnt_Lacky » 07 Apr 2012, 02:02
nelson wrote: After I posted this I dumped the rotary switch and 4053 in favour of an SPDT toggle for the disconnecting the LFO and switching to A steady DC and a 3PDT toggle for the other changes in the audio path and the clock cap. I ended up replacing the blend switch with a full wet/dry blend pot and added a gain recovery stage at the output. All 4 functions work as they did before. Just two toggles instead of one rotary and those two CD4053.
Sounds like you did quite a bit of choppin'!
Should make the layout quite a bit smaller. Definitely a lot faster than me :oops:
Can't wait to see it :applause:
Govmnt_Lacky
Re: EH Echoflanger
Postby nelson » 07 Apr 2012, 13:51
Here's the schematic.
Should make it clearer how I modified the circuit.
For this message the author nelson has received thanks: 4
asatbluesboy (26 Jul 2012, 17:29), mister707 (18 Sep 2012, 19:46), sodapep2 (26 Jul 2012, 00:14), tp801 (08 Apr 2012, 08:32)
nelson
Re: EH Echoflanger
Postby PmCimini » 16 Apr 2012, 12:58
it does seem okay, any builds? the new stereo poly chorus (both large chassis and die-cast aluminum) run with one MN3008 and one MN3009. Suprised to not see any gutshots of those here... The circuitry is a lot different, but does anyone know how it compares to the sound of the old one?
PmCimini
Has thanked: 24 times
Have thanks: 3 times
Re: EH Echoflanger
Postby Govmnt_Lacky » 16 Apr 2012, 13:07
PmCimini wrote:it does seem okay, any builds? the new stereo poly chorus (both large chassis and die-cast aluminum) run with one MN3008 and one MN3009. Suprised to not see any gutshots of those here... The circuitry is a lot different, but does anyone know how it compares to the sound of the old one?
This seems odd to me. Seeing as the original Echoflanger circuit (which is reported to be the same circuit that was used in the Polychorus... just a name change) used (2) SAD1024 chips. One chip in series (1024 stages) and one chip in parallel (512 stages)
Now, seeing as the newer versions use MN3008 (2048 stages) and MN3009 (256 stages) I can only assume that they achieve the same results by altering the clock signal :hmmm:
Very odd.
Govmnt_Lacky
Re: EH Echoflanger
Postby nelson » 16 Apr 2012, 19:29
Very odd.
I have a schematic of the reissue. It's extensively modified from the original. It uses the 256 stage bbd for the flange/filter matrix and the 2048 for the chorus/slapback. The LFO is different. The set up for the tune/width controls is changed.
It will react and sound quite different to the original.
nelson
Re: EH Echoflanger
Postby GodSaveMetal » 01 Jul 2012, 17:59
Great MAN!!!!! would you please can made a PCB and a layout from these?? thanks a lot!!!! million thanks!!!!! :applause: :applause:
GodSaveMetal
Has thanked: 141 times
Have thanks: 52 times
Re: EH Echoflanger
Postby uncleboko » 01 Jul 2012, 18:06
Very odd.
The circuit I saw used MN3008 & MN3009
uncleboko
Has thanked: 55 times
Have thanks: 21 times
Re: EH Echoflanger
Postby sodapep2 » 26 Jul 2012, 00:14
Hey Nelson, nice schematic! I'm looking into making a PCB for it, however I'm a bit confused as to where 'to clock timing cap' goes on SW1G$3 next to R36 on the right middle side of the audio schematic. I can't seem to find its mate.
sodapep2
Have thanks: 2 times
Re: EH Echoflanger
Postby Govmnt_Lacky » 26 Jul 2012, 16:42
sodapep2 wrote:Hey Nelson, nice schematic! I'm looking into making a PCB for it, however I'm a bit confused as to where 'to clock timing cap' goes on SW1G$3 next to R36 on the right middle side of the audio schematic. I can't seem to find its mate.
I believe it goes to the "CH/FL Switch" on the first sheet. The change in cap values is needed to switch the delay rates.
Govmnt_Lacky
Re: EH Echoflanger
Postby sodapep2 » 02 Aug 2012, 02:23
I see. So 'to clock timing cap' = 'To CH/FLSwitch'. Thanks!
sodapep2
Re: EH Echoflanger
Postby sodapep2 » 02 Aug 2012, 03:53
I also gotta say, what's up with the odd resistor values?
3.01k? :?
sodapep2
Re: EH Echoflanger
Postby Govmnt_Lacky » 08 Aug 2012, 20:22
sodapep2 wrote:I also gotta say, what's up with the odd resistor values?
3.01k? :?
My guess is that EH used whatever they had on-hand at the time.
Not much difference between a 3K and a 3.01K :thumbsup
Govmnt_Lacky
Re: EH Echoflanger
Postby Govmnt_Lacky » 19 Aug 2012, 00:19
Any progress/news on this?
Govmnt_Lacky
Re: EH Echoflanger
Postby sodapep2 » 19 Aug 2012, 19:46
Making progress. Right in the middle of busy season (harvest), so it's slow but it's getting there!
For this message the author sodapep2 has received thanks:
GodSaveMetal (02 Sep 2012, 00:01)
sodapep2
Re: EH Echoflanger
Postby GodSaveMetal » 19 Aug 2012, 20:20
sodapep2 wrote:Making progress. Right in the middle of busy season (harvest), so it's slow but it's getting there!
GOODNESSS!!! the force is with you!!!!!!!!!!!!!!!! get it man!!!!!!!! :twisted: :twisted:
GodSaveMetal
Re: EH Echoflanger
Postby Govmnt_Lacky » 01 Sep 2012, 22:47
Cruzin' through here and gotta ask...
Any new progress sodapep? :applause:
Govmnt_Lacky
Re: EH Echoflanger
Postby GodSaveMetal » 02 Sep 2012, 00:02
Govmnt_Lacky wrote:Cruzin' through here and gotta ask...
Yeahhh my friend sodapep, got´em THE FORCE IS WITH YOU!!!!!!!!!!!!!!!!! :horsey:
GodSaveMetal
Re: EH Echoflanger
Postby Govmnt_Lacky » 22 Sep 2012, 22:08
Any news on this soda?
Govmnt_Lacky
Users browsing this forum: sleepingtiger and 7 guests
