Jordan - Bosstone  [schematic]
Jordan - Bosstone
Postby drewl » 17 Feb 2010, 18:53
Anyone ever build one of these?
I was bored so I slapped one together. It won't work with the 150k resistor from Q1's base to ground no matter what value I tried.
Anyway, I have a test box for trying new circuits I can wire it up to and try it when I get home.
drewl
Have thanks: 4 times
Re: Jordan Bosstone?
Postby Dan N » 17 Feb 2010, 19:51
There are several schematics, including a known wrong one. Which did you use?
Dick joke has expired.
Dan N
Has thanked: 54 times
Have thanks: 19 times
Re: Jordan - Bosstone
Postby The Rotagilla » 18 Feb 2010, 05:22
Built one, tried both schematics and was underwhelmed. :|
The Rotagilla
Have thanks: 57 times
Postby drewl » 18 Feb 2010, 14:45
I built this one below
http://schematicheaven.com/effects/jordan_bosstone.pdf
I found another schem with the second transistor a PNP, so I don't know which was the wrong version.
I'll swap Q2 and see.
It's kinda like the EH Muff Fuzz.
drewl
Postby IvIark » 18 Feb 2010, 14:49
Yes Q2 should be PNP
IvIark
Has thanked: 668 times
Have thanks: 678 times
Postby drewl » 18 Feb 2010, 15:26
I tried it out and with the correct Q2 and it works with the Q1 base resistor.
Not that I'll ever use this thing, I've got like a dozen little boards lying around of different fuzzes I've built for the heck of it.
If they sound great, then they get put into a pedal.
drewl
Postby jrod » 18 Feb 2010, 15:42
Dan N wrote:There are several schematics, including a known wrong one. Which did you use?
For clarification, please, is this the known wrong schematic? http://schematicheaven.com/effects/jordan_bosstone.pdf
jrod
Has thanked: 326 times
Have thanks: 41 times
Postby drewl » 18 Feb 2010, 16:18
It seems so.
Q2 should be a PNP with the collector grounded.
With an NPN in Q2 spot it won't work with the 150k resistor from Q1's base to ground.
It works without the 150K, but the waveform is quite different from the correct version.
I haven't tried them out to see what they sound like yet, who knows...maybe the "wrong" version might sound better. :D
drewl
Re: Jordan Bosstone?  [schematic]
Postby Dan N » 18 Feb 2010, 22:28
Yes! That is the infamous wrong version.
AG has the right one: http://analogguru.100free.com/193/schem ... sstone.gif
There is also an earlier Alhambra, California NPN/NPN version with a couple parts that need values: http://users.rio.com/senorris/jordanbt/ ... CA%232.gif
I think it's a great sounding fuzz.
Dan N
Postby John Lyons » 18 Feb 2010, 22:40
I think there are 4 different versions actually.
Or at least I have 4 different schematics for it
that are all different.
Boss tone rules!
John Lyons
Have thanks: 26 times
Postby johnnyg » 18 Feb 2010, 22:42
John Lyons wrote: Boss tone rules!
I completely agree!
It can get very ratty and nasty sounding - it's borderline distortion with the clipping diodes. It's a lot of fun (if you're into the Stooges kind of thing, you should like it a lot). You get weird oscillation with the attack knob (or whatever it's called) dialed fully one way.
I built mine point-to-point using IvIark's layout on here - viewtopic.php?f=13&t=8193&start=300
johnnyg
Has thanked: 102 times
Have thanks: 49 times
Postby Dan N » 18 Feb 2010, 23:20
Oh yea, a later Alhambra. Other than the first pot, no mystery parts: http://users.rio.com/senorris/junk/bosstoneCA%3f.gif
Dan N
Postby RnFR » 19 Feb 2010, 11:10
build the one that AG's got on his site. it sounds great.
[smilie=bowdown.gif] STOOGES!
Has thanked: 150 times
Have thanks: 174 times
Postby drewl » 19 Feb 2010, 23:18
Wow, I think this one's a keeper!
I built AG's, so far just an output pot, with run of the mill 2n3904's.
it cleans up pretty good when the guitar volume is rolled back and produces some great nasty distortion when cranked with nice overtones and bloomage!
drewl
Postby Alex Frias » 21 Feb 2010, 22:44
I tried several trannies combination and found low hfe ones offering the best sound!
Alex Frias
Have thanks: 13 times
Postby Alex Frias » 21 Feb 2010, 23:26
Bu I was talking about the NPN, the Q1, ok?
Alex Frias
Postby RnFR » 22 Feb 2010, 00:20
Alex Frias wrote:Bu I was talking about the NPN, the Q1, ok?
yeah, 2n222's are good.
Postby fuzzbuzzfuzz » 26 May 2010, 15:41
Interesting thread... :D
I have a Bosstone Clone - build around the GGG JBT board and parts-list, identical in every component, however I`m a little disappointment with the sound.... :?
I don`t own an original for comparison, but I`m judging by this JBT on Youtube:
http://www.youtube.com/watch?v=VK2r0oEPU3s
The build I have has none of the thick octave overtones (which I think are very much part of the Bosstones signature characteristics) and seems much thinner soundwise.
Any ideas why? I checked every component and it seems identical to the JBT...strange!
Thanks :o
fuzzbuzzfuzz
Postby mikemaddux » 31 May 2010, 22:23
Build it with sag control - great trumpet tones and other stuff
http://www.youtube.com/watch?v=6z5pQIQFOak
mikemaddux
Postby Alex Frias » 04 Jun 2010, 04:18
Yes, I did it some time ago, just using a 100k pot for the SAG and increase a bit the caps values.
http://www.youtube.com/watch?v=78XVvOXcecY
Otherwise in order to achieve more interesting Jordan Bosstone mild distortion tone I prefer to use low gain trannies and keep the original caps values.
Alex Frias
Next
Users browsing this forum: cctsim and 10 guests
