Sola Sound - Tonebender Mark II Professional  [schematic]
Re: Sola Sound - Tonebender Mark II Professional
Postby Electric Warrior » 02 Dec 2017, 23:15
It's too little leakage for your bias setup, at least if you're going for the OC75/OC81D style thing. You could try 100k on Q1's base and 100k on Q2's collector. I hope that gets you close. They were biased to around 0.16V on Q2C. Hiss is not much of an issue in this voltage range. It's more prone to gating, but the gating can sound quite good.
That said, your Q1C looks like it could be in the right ballpark with the 10k, but I guess your battery voltage may be rather low.
For this message the author Electric Warrior has received thanks:
Rocket Roll (02 Dec 2017, 23:27)
Electric Warrior
Has thanked: 20 times
Have thanks: 82 times
Postby Rocket Roll » 02 Dec 2017, 23:24
Electric Warrior wrote:It's too little leakage for your bias setup...
Well, that's exactly the greatest part of the problem - those are the transistors that are supposed be selected to work well in a ToneBender by the good people in BYOC, right? If so, why aren't they?
Electric Warrior wrote:They were biased to around 0.16V on Q2C.
Great info, thanks!
Electric Warrior wrote:That said, your Q1C looks like it could be in the right ballpark with the 10k, but I guess your battery voltage may be rather low.
Forgot to mention - all measures taken with a laboratory supply at exactly 9.00V.
Rocket Roll
Has thanked: 10 times
Have thanks: 27 times
Postby Electric Warrior » 02 Dec 2017, 23:50
I guess it wasn't all that well known when they started out and they followed the general recommendations at that time. As you can see from the schematic, they had no chance to get this right.
Considering your supply voltage, Q1C is rather high. I'd definitely use a bigger resistor on its base.
Rocket Roll (03 Dec 2017, 08:45)
Electric Warrior
Postby Rocket Roll » 03 Dec 2017, 08:45
Electric Warrior wrote:Considering your supply voltage, Q1C is rather high. I'd definitely use a bigger resistor on its base.
Thanks! Any recommendations? Which voltage do I aim for?
Rocket Roll
Postby Electric Warrior » 03 Dec 2017, 11:45
Around 90 to 95% of the supply voltage, so between 8.1 and 8.55 V would be dead on.
If the 100k on Q2C does the trick, A 100k for Q1B should be alright.
Rocket Roll (03 Dec 2017, 13:46)
Electric Warrior
Postby Rocket Roll » 03 Dec 2017, 13:58
I'll try. One question, if I may...
I've got a small stash of germanium transistors that I can experiment with. Given the above numbers, what kind of leakage (IC and/or ICE0) am I looking for?
Rocket Roll
Postby Electric Warrior » 03 Dec 2017, 15:12
You could try around 0.35 mA. Whatever gets you in the right ballpark. Higher leakage should bring down the voltages on Q1C and Q2C, while the one on Q3C increases.
Rocket Roll (03 Dec 2017, 22:33)
Electric Warrior
Postby Rocket Roll » 12 Dec 2017, 19:04
I've seen that SmallBear now stocks Amperex 2N281 transistors which are made in Holland, and according to this excellent read (https://sites.google.com/site/transisto ... rs/philips) they should correspond to Phillips OC72 type. I've ordered a set and received this:
SmallBear measurements, as written on the bags:
Q1 - hFE 60, L(eakage) 125
Q2 - hFE 92, L(eakage) 158
Q3 - hFE 158, L(eakage) 181
Chinese transistor tester measurements:
Q1 - hFE 54, ICE0 67uA, ICEs 5uA
Q2 - hFE 96, ICE0 .20mA, ICEs 8uA
Q3 - hFE 186, ICE0 .33mA, ICEs 11uA
I've dropped them in a ToneBender MKII OC75 schematic, without any resistor substitutions, and got this:
In-circuit measurements, taken at 8.99V:
Q1, E 0.00, B 0.02, C 8.86V
Q2, E 0.00, B 0.08, C 0.15V
Q3, E 0.08, B 0.15, C 8.20V
The sound? It fuzzes allright, but let me put it this way: if I were someone who listened to all of the ToneBender lore and then got introduced to this sound, I would've thought that I'm simply not a fuzz person.
In this particular setup, they do not show more than 10% of the ToneBender potential. The sound is velcro-ish, octavey, gated. It is very present and "real", but not really pleasant.
If I haven't already completed two ToneBenders and somehow got crazily lucky with them (they sound very "Marshall in a box"-like, gainy and creamy, almost BigMuffish), I would've thought that ToneBenders are simply not my cup of tea, and that any zVex Fuzz Factory could do a number of such tricks, without the mythology attached.
So, do I change the transistor order and try to coax something out of this circuit as it is, or do I change the resistors - that is the question now...
Rocket Roll
Postby Electric Warrior » 15 Dec 2017, 20:38
Right.. voltages are one thing. Tone is another.
You've got a really wide spread of gains here, which probably makes things more complicated than they need to be.
Also, Q1 obviously has too little leakage.
Why don't you go through your stash of germaniums and see what works well for you?
Electric Warrior
Postby fuzzbunny » 16 Dec 2017, 08:34
@Electric Warrior
I just wanted to say that you are an awesome individual. So many times I have seen you step up and offer your valuable knowledge on vintage germanium circuits. Thank you!
For this message the author fuzzbunny has received thanks:
jreeves47 (10 Jan 2018, 19:07)
fuzzbunny
Have thanks: 6 times
Postby tonycaster » 04 Jan 2018, 06:46
What do you guys think about using a 33 k on Q2 collector? I've done that in few tb mk2 i built and i think it gives me much more 'range', i can use the fuzz even when it's super hot cos the 33k it's balancing with the leakage when increasing.
The sound is never gated.
At room temperature the bias on Q2 collector is 0.6v
tonycaster
Postby Rocket Roll » 04 Jan 2018, 13:11
I've ordered a ToneBender set from diyguitarpedals.com.au - http://www.diyguitarpedals.com.au/shop/ ... ducts_id=6
The transistors look the part:
It came with these marked values:
Q1 Collector current (IC) 828, Leakage (ICL) 159, hFE 73
Q2 Collector current (IC) 818, Leakage (ICL) 146, hFE 73
Q3 Collector current (IC) 1182, Leakage (ICL) 185, hFE 108
My meter tells me this:
Q1 hFE 71, IC 1.0mA, ICE0 .25mA, ICEs 12uA
Q2 hFE 74, IC 1.1mA, ICE0 .30mA, ICEs 15uA
Q3 hFE 102, IC 1.4mA, ICE0 .32mA, ICEs 14uA
I haven't measured the voltages, but by ear, after I've replaced the first SmallBear's "Flying Dutchman" (2N281) in my BYOC build with the middle AC125 (the one with hFE73), the sound got fuzzier, which is to say less like distortion and more like fuzz ("mushier", "looser", "spongier"). It's a pleasant sound alltogether. I'll leave that transistor there for the time being.
Rocket Roll
