Sola Sound - Tonebender Mark II Professional  [schematic]
Re: Sola Sound - Tonebender Mark II Professional
Postby Electric Warrior » 05 Apr 2014, 11:50
copachino wrote:
LucifersTrip wrote:I'm not sure if Small Bear gives you correct transistors for an authentic MKII. I remember multiple times someone posted that
Q3C voltage hits 4.5V (instead of 7.5V-8.5V+ like originals).
A couple quick searches, I found this one
http://www.diystompboxes.com/smfforum/i ... ic=45496.0
WAITTTTT.. am i missed something???, as far as i remenber fuzz central, in the sola sound schematic says that the value for Q3 its -4.5v..... where did you get thos 7.5v???
Here:
Actually this one measures 8.44V.
7.5 is low for a vintage unit. Most seem to measure over 8V.
Careful with that fuzz central site. Most of the MKII schematics have issues.
For this message the author Electric Warrior has received thanks:
jalmonsalmon (05 Apr 2014, 17:43)
Electric Warrior
Has thanked: 21 times
Have thanks: 89 times
Postby copachino » 05 Apr 2014, 14:04
OC75??? i was really sure that original units used OC81D, also in the D:A.M site says that OC81D are the real transsitors
copachino
Have thanks: 6 times
Postby Electric Warrior » 05 Apr 2014, 14:32
I suggest you read the D*A*M site again, even though the history section is not quite up to date and may lead to confusion about a couple of things.
This very thread is also worth reading.
Most MKIIs came with OC75s or Impex S3-1Ts. The OC81D-version was a short lived variant that was made shortly before production ceased.
Electric Warrior
Postby jalmonsalmon » 05 Apr 2014, 17:41
It is about 70ºF in my room and my OC75s from small bear are measuring these readings now from using R.G. Keens tester
Q1
327 uA
76 hFE
Q2
268 uA
91 hFE
Q3
255 uA
157 hFE
Currently my tone bender is following the orig schematic for the OC75 version except of course mine has .015 in and out caps... 4.7uF and 47uF instead of the 5uF and 50uF and 100k to Q1 base to ground - Q2 collector is 50k instead of 47k and
Q3 collector is at 20k - I can probally even raise Q2 collector to maybe near 60k but anyway these are the readings I get now:
Q1
C 6.26
B .073
E 0
Q2
C .171
B .078
E 0
Q3
C 7.3
B .173
E .102
Now with that :horsey: LOL if I turn down the Q3 collector to the 8k2 value the Q3 collector will read about 4.7 volts... and the pedal is very very squishy and distorted.. sounds great that way and super fuzzy however I like the sound of Q3's collector at >7 volts and from that point I start hearing that Jimmy Page sound - bottom line from my observations, the transistors from small bear can be hit or miss... make sure you can get Q3's collector past 7 volts and even up to 8 volts if you can, to nail the Zeppelin sounds from the old records. IMO look for a trio of OC84s, they are really great transistors and easier to work with :secret:
jalmonsalmon
Has thanked: 81 times
Have thanks: 24 times
Postby jalmonsalmon » 05 Apr 2014, 17:58
jalmonsalmon wrote:It is about 70ºF in my room and my OC75s from small bear are measuring these readings now from using R.G. Keens tester
Woops my bad... those readings were with a battery that is dying and was at 8 volts... I put a fresh battery in and Q3 collector voltage is 8.25 volts with the Q2 collector bias resistor set at about 47k
Q3 bias at 20k... if I back Q3 bias to the stock 8k2 I get about 5.25 volts... My bad LOL
:slap: *Remember to use a fresh battery for testing!* :slap:
Nails Zep in spades lol... if I have time I will try and get a clip posted too
sorry for all the posts here... :oops:
jalmonsalmon
Postby Electric Warrior » 05 Apr 2014, 18:41
That's extremely low for stock values. Have you tried swapping the transistors around?
Electric Warrior
Postby Electric Warrior » 05 Apr 2014, 19:06
Oh, wait. Change the resistor on Q1's base to 10k first (no need to solder, just connect a 10k in parallel with the 100k temporarily) and see if that changes anything.
jalmonsalmon (05 Apr 2014, 22:46)
Electric Warrior
Postby jalmonsalmon » 05 Apr 2014, 22:48
Electric Warrior wrote:Oh, wait. Change the resistor on Q1's base to 10k first (no need to solder, just connect a 10k in parallel with the 100k temporarily) and see if that changes anything.
Soon as I get a chance I will try the 10k in parallel to see what happens... I am suspect of the gains of Q3 as well because that is a HOT transistor and seems to be overkill LOL I have a few other OC75s I can try out as well and will swap them around later.
jalmonsalmon
Postby Electric Warrior » 05 Apr 2014, 22:56
Not sure if it will change anything about the voltages you're reading at Q2 and Q3, but it sure is worth a shot.
It's a really wide spread of gains you've got there. Maybe that's the problem. I usually end up with something that's matched more closely. Swapping around OC75s while using the stock resistor setup should get you something good and vintage sounding (and measuring) easily. Let me know how it goes!
Electric Warrior
Postby jalmonsalmon » 09 Apr 2014, 17:31
Electric Warrior wrote:Not sure if it will change anything about the voltages you're reading at Q2 and Q3, but it sure is worth a shot.
I had a chance to put this circuit on a breadboard and now I am getting the proper voltages, however it is pretty gated with my orig OC75s... I have a trio of OC84s that are doing better but the Q2 bias resistor sounds better at about 30k-40k
I kept the Q3 bias at a fixed 8.2k. It is not too gated this way and I am still pulling in a good 8.4 volts on Q3 c... Fun circuit! :applause: Bread-boarding this really helped me understand what is going on here.
jalmonsalmon
Postby Electric Warrior » 10 Apr 2014, 07:32
Excellent!
I usually swap Q2 until I find one that gives it just the right balance of gating and clean up. A trim pot sure can come in handy there, though I've never felt I needed one.
Electric Warrior
Postby jalmonsalmon » 10 Apr 2014, 21:17
Electric Warrior wrote:Excellent!
I GOT IT!!!! Yeah I was swapping out Q2 around and then my strings started to feedback and I knew I hit it LOL.. sustain
I can use the exact stock values from your schematic (OC75) and it works perfectly with this other set of OC84s I found. In fact I can actually increase Q2 collector from 47k to about 60k or even 100k and it still will not gate and the voltages will start to get into the 8.7v range... I Will take some readings and measure the transistors again ... post the results
Was kind of funny because I took my POTs off the bread board and accidentally put the 8.2k on collector or Q2 and the 47k on the collector of Q3 and fired up the pedal... sounded great hahaha but measured the voltage off of Q3 collector and saw like 6v so I was really puzzled until I found my error...
Soon as I get a chance I will box her back up and try and get a youtube clip going...
Thanks again!
jalmonsalmon
Postby Electric Warrior » 10 Apr 2014, 21:42
Congratulations!
Just wait until temperature changes kick in. :mrgreen:
But as long as it's open, but not hissy at room temperature, it will probably work reasonably well in most situations you will encounter.
Electric Warrior
Postby jalmonsalmon » 11 Apr 2014, 16:40
Electric Warrior wrote:Congratulations!
It stays about 75ºF - 78ºF in here but I remember taking a fuzz face to a gig ( I live in Texas ) and it was 105ºF outside... At the gig they did not really have any A/C, just big fans blowing and that fuzz face was pissing me off LOL
reistance to Q2 bias was way too high for that night so I just tossed that pedal back in the bag
jalmonsalmon
Postby Electric Warrior » 11 Apr 2014, 17:55
Oh yeah, that's really warm. I wouldn't expect my germanium fuzzes to work well at 105°F. They can handle about 85° to 90°, though. My vintage unit gets quite gated and spitty above 85, but still kinda useable. I wouldn't want to gig at that temperature, though.
Electric Warrior
Postby Masuto » 13 Apr 2014, 06:05
bato001 wrote:Keep us up to date on your build. Looks good so far!!! Post pics, Voltages and a sound clip if you can. :thumbsup
Here is my OC84 build..
http://m.soundcloud.com/masutomasuto/tone-bender-oc84
What do you folks think?
Sorry for the crap playing...i am not really a guitarist.
I also managed to mess up my oc75 build into a square wave synth ahaha (i will post clip before debug)
For this message the author Masuto has received thanks:
bato001 (13 Apr 2014, 14:08)
Masuto
Has thanked: 42 times
Have thanks: 5 times
Postby bato001 » 13 Apr 2014, 14:09
Real nice. Good work! :applause:
bato001
Has thanked: 46 times
Have thanks: 58 times
Postby Masuto » 13 Apr 2014, 17:08
bato001 wrote:Real nice. Good work! :applause:
Ah! Thank you! :lol: happy now
Masuto
Postby jrod » 13 Apr 2014, 19:24
Sounds great!
For this message the author jrod has received thanks:
Masuto (13 Apr 2014, 22:03)
jrod
Has thanked: 336 times
Have thanks: 42 times
Postby copachino » 10 May 2014, 06:31
i already got build mine tonebender, here are some pics,
voltages at bias are.
Q1, -8.5v
Q2: -1.2v
Q3: -7.6v
i had it before Q3 at -4:5v but, it sounded more like a high gain distor than a fuzz, so a re biased at -7.6v and it sounds like hell, its really nasty and cool, i love it
copachino
Users browsing this forum: MSN [Bot] and 9 guests
