Sovtek MIG50H (detailed)
My particular amp (stock) differs from the schematic in several ways.
When there is nothing plugged into the high gain input, the screen of gets connected straight to earth without going through R10. There is another connection in green (on the enclosed schematic) which differs, as well as two extra resistors, and some with differing values.
I have also noted the correct fuse values and the AC voltages coming from the transformer.
There are two resistors in the heater circuit, they are not on either schematic.
- heater-resistors.png (335.16 KiB) Viewed 5977 times
Detail around the power valves. Note that the 15K ohm resistor is stock, not Russian and not on the schematic (I bought this amp new).
- mig-valves.png (332.29 KiB) Viewed 5975 times
Line output. I tried to record from this years ago, without success. I may try again.
- rec-out.png (281.38 KiB) Viewed 5975 times
I am not getting any signal out of the line output. I tried a 4-track cassette, a computer, and no signal. I checked the cable each time by plugging my guitar straight into it, and there was a signal that way.
I checked out the resistors earlier and resoldered them. No signal and I have never gotten any signal, as I tried this many years ago as well.
Anyone have any idea as to how this is supposed to work?
I guess I'll check the connections again later when I decide to open it up again, but I have a feeling I've done this before. I guess it's just as well that it doesn't work because I need an extra hole for mods, but it still bugs me.
Another thing I wanted to point out about this amp is the cathode resistors. One was fried as in the above pic, and the other measures about 90K, which bumps the plate voltage to over 300V. Right now I have a long plate valve in there, but I'll put in another of closer value so I can put whatever valve I want in there.
A 100K resistor is what I meant, if it's unclear.Sir Fayzalot wrote:Another thing I wanted to point out about this amp is the cathode resistors. One was fried as in the above pic, and the other measures about 90K, which bumps the plate voltage to over 300V. Right now I have a long plate valve in there, but I'll put in another of closer value so I can put whatever valve I want in there.
- phatt
- Transistor Tuner
That line out does not make senseSir Fayzalot wrote:I am not getting any signal out of the line output. I tried a 4-track cassette, a computer, and no signal. I checked the cable each time by plugging my guitar straight into it, and there was a signal that way.
If it's standard socket then when you insert a plug then R27 would be shorted to ground = no line signal
It maybe a factory stuff up. As I;m not able to see the other side it's a guess but worth checking.
Phil.
No it wouldn't, part of the signal would go to the hot connection on the jack, part of it would go to R26 and then earth/ground.phatt wrote:That line out does not make senseSir Fayzalot wrote:I am not getting any signal out of the line output. I tried a 4-track cassette, a computer, and no signal. I checked the cable each time by plugging my guitar straight into it, and there was a signal that way.
Phil.
However, it doesn't work. There is a similar line out with a couple of capacitors added on the MIG-60, if you care to look that up. Apparently someone has gotten it to work but does not appreciate the sound:
https://www.thegearpage.net/board/index ... w.1511734/
And in this thread there is someone who allegedly likes the line out on the MIG-50H:
http://www.marshallforum.com/threads/ma ... out.33387/
Although I'll take it with a grain of salt, people sometimes mention the wrong amp on forums.
- phatt
- Transistor Tuner
Well that socket has 6 tabs which tells me it's a stereo switching unit and the middle terminal is used as a mount for junction of Speaker Hot and R27.
Now if it was wired up wrong side then there would be No signal.
It would not be the first time a factory product went out the door with a wiring fault.
Easy to check and simple to fix. Up to you
Phil.
Phil.
I see what you're saying, but I thought it was pretty much standard that the side which is active is the left side looking from outside the chassis from where you plug in a cable into the jack. The lugs on the right side are suppose to connect to the ones on left side when nothing is plugged in.phatt wrote:Well that socket has 6 tabs which tells me it's a stereo switching unit and the middle terminal is used as a mount for junction of Speaker Hot and R27.
Phil.
All the jacks are set up like this on this amp in any case (look at the above picture with the speaker jacks), and all the switching jacks I've had my hands on are set up like this.
However, the line out jack is faulty. This is not uncommon for this type of jack. That's the one that came with the amp, but all the switching jacks I've bought new locally have been faulty in one way or another.
I only use the kind of jacks that go into Marshalls now. I don't think I'll waste one for a line out I'm not going to use though, I have quite a few mods planned that I might even have to go with a rotary switch.
Changed the plate resistor with low resistance to one that has 100.8K ohms and now I'm getting 290V on the plate, which is what I wanted so I can use any ECC83/12AX7 without frying it.
I'm going to change some of the pots, I noticed they are stamped "MOUSER".
It's a real pain to work on this, space is tight and I've ripped some of the leads to the main board several times, changed a few as well. The amp is just as heavy as the non-master volume MIG-50 because of the heavy transformers, so I'm not sure of advantages of it being small, but it does look and sound good.
I'm thinking this amp is related, other than the bass version of the MIG-50H (MIG-500) and the 100 watt amps:
http://oecc.ru/amplifier/forte-tube-50
This isn't Sovtek, but it was also made in Saint Petersburg. It was part of a small run in the 90s, possibly made at the same time as the Sovteks. The panel and top of the cab are more Fender looking and the amp has an effects loop. The earlier amps in this series were solid-state and had the controls labeled in Russian.
Also want to point out that in the 8th post I wrote "cathode resistors" but meant "plate resistors".
Hey Guys,
I realize this thread is a few years old but hoping the op can help me out. I recently got one of these in a trade. When I popped it open, it appears someone has attempted to redo the heater wiring. The pair of leads that feed V1 are now hanging free. There is also a black insulated lead that comes from under the board towards the output jacks that is disconnected on that end. It appears to be connected on the other end to the 2 small leads that join the board between D3 and RX in your picture. For the life of me I can't figure out where it is supposed to go from the schematic. Any idea?
The loose wire going toward the output jacks is probably the global negative feedback, if so, it should be connected to the tip of the 8 ohm output jack. Hard to give you advice without pictures or more information. The v1 heater uses a separate dc supply, would be easy enough to confirm whether or not that circuit is working and reattach the leads.
