I'm building an amp with the trinity 18 watt set and wanted an option to run either a 6ca4 or a 5y3, but instead of separate 5v and 6v windings, there's just a tap on the 6v for the 5v, so this is what I was thinking:
Should work fine for an either/or setup, but I think there might be a problem if both tubes happened to be plugged in at the same time by accident. What do you guys think?
Trinity power transformer question
- KindaFuzzy
- Degoop Doctor
