Help on Marshall Bass State B65 transformer
Postby arcaarca » 05 Feb 2014, 13:00
Hi everyone,
a friend of mine gave me a Marshall Bass State B65 combo. The transformer is broken, it's a Dagnall transformer type D9609.
The final stage of this amp is very similar to Valvestate V65 amp, whit T64-T65 power transistors:
http://www.drtube.com/schematics/marshall/pc0689p.pdf
one of the mainly differences is the couple of resistors R101-R102, they are 470 ohm in B65.
The trafo specifications for Valvestate 65 are Dagnall D9601 or Drake 784-352
I need some help on get the transformer specifications, I think it could be a 24-0-24 or maybe little more, but I'm not so good with trafo stuff and I'd like start to learn something ;-)
Thanks a lot
arcaarca
Has thanked: 28 times
Have thanks: 10 times
Re: Help on Marshall Bass State B65 transformer
Postby phatt » 07 Feb 2014, 12:31
Your description of problem is a bit vague,
Can I ask How you established that the transformer has blown?
Have you checked FS1 ? (the mains fuse)
Phil.
phatt
Have thanks: 266 times
Postby DrNomis » 07 Feb 2014, 12:44
arcaarca wrote:Hi everyone,
Thanks a lot
Have you tried googling for the specs for that transformer?...... :hmmm:
Has thanked: 123 times
Have thanks: 401 times
Postby arcaarca » 08 Feb 2014, 17:59
to Phatt: I've checked main fuse, it was blown and it blowns when I turn on the main switch, even if I use only the transformer, removing the wires from secondary to pcb, so I think the problem should be on the transformer,
to DrNomis: I'm still googling around, I found many specifications for other Dagnall transformers, but no one for the D9609 or D96.. series :x
Full description on the transformer is:
TX3
D9609 9546
Dagnall Electronics Ltd
arcaarca
Postby phatt » 08 Feb 2014, 22:59
OK, yes sounds terminal but it still could be a faulty power switch. I'd Try removing it from circuit before I give up. (assuming switch is after fuse)
If Transformer then yes likely the circuit runs from 35~40 volt DC rails so any Transformer that outputs 25~28 x2 VAC will likely make it work again.
Time to hunt down old stereo equipment that are often now collecting dust or trashed at the local tip. :secret:
Phil.
For this message the author phatt has received thanks:
arcaarca (09 Feb 2014, 14:03)
phatt
Postby deltafred » 09 Feb 2014, 00:25
To give 65W at 8 ohms you need a minimum transformer voltage of about 24v for each winding with a total current of at least 3A (1.5A per winding). Probably best to go a bit higher on the current so you don't cook the transformer, 2A per winding should be fine.
So as Phatt says about 25v or a bit more, don't go too high otherwise you will be needing a new speaker (driver) if you get a bit carried away with the volume control.
For this message the author deltafred has received thanks:
deltafred
Has thanked: 389 times
Have thanks: 263 times
Postby arcaarca » 12 Feb 2014, 17:58
The fuse is after the power switch, and before the transformer, so I think the problem is "just" the transformer.. sigh!!
I'll have to looking for some good stuff, maybe 2nd hand store or similar... thanks a lot to everyone for suggestions and support!
arcaarca
Postby ilcaccillo » 12 Jan 2018, 01:55
phatt wrote:OK, yes sounds terminal but it still could be a faulty power switch. I'd Try removing it from circuit before I give up. (assuming switch is after fuse)
Phil.
In the schematic the rails are +15V and -15V and not "35~40 volt DC rails"
ilcaccillo
Have thanks: 19 times
Postby Ice-9 » 12 Jan 2018, 02:42
It is probably a close spec Tx to the V65 but as you have only posted the part of the schematic for the V65 and not the bas state B65 and I am unable to find the correct schematic for the B65 it is not possible to say. Your easiest solution would be to email either Drake or Marshall for the Tx spec. I have had regular dealings with Marshall and always have had them give me the info needed. They have even sold me replacement transformers for JMP1's. Give them an email, probs the quickest answer you will get.
PS , i'm guessing by its model name it has a preamp valve, so the TX will have multiple windings for high voltage and heaters for the valve and low voltage windings for solid state circuits. Marshall generally use +/- 15V DC for op amp parts and somewhere between +/-25V to +/-35V for the output stages.
Ice-9
Has thanked: 141 times
Have thanks: 361 times
Postby Manfred » 12 Jan 2018, 10:02
I had have a Valvestate V80 for repair in the past, parts of the power supply are the same as these in the V65.
I noted down the read voltages.
Manfred
Has thanked: 1007 times
Have thanks: 576 times
Postby ilcaccillo » 06 Feb 2018, 01:02
Ohh I see,
thats correct, thanks for clearing this up
ilcaccillo
Return to Amplifiers
