1973 Kasino U100-P repair question
Postby ljn » 30 Nov 2014, 02:02
Hi. I have an old kasino amplifier that used to be my favorite amp until a part went bad. The part looks like a germanium transistor, and has the number 61008 printed on it. It appears they used it as a diode. My question is this. What can I use as a replacement? I'd really like to get this one working again. Any suggestions would be greatly appreciated. Thank you.
Education is 10% knowledge and 90% brainwashing. We're only told what they want us to know. The rest is fabrication in it's purest form.
ljn
Have thanks: 8 times
Re: 1973 Kasino U100-P repair question
Postby DrNomis » 30 Nov 2014, 02:08
Not sure, if you could post a schematic diagram that would help a lot...... :thumbsup
Has thanked: 123 times
Have thanks: 401 times
Postby ljn » 30 Nov 2014, 02:11
I never could find a schematic for it.
ljn
Postby ljn » 30 Nov 2014, 02:18
This amp really sounded great when it was working. I got it for $40 at a pawn shop and used it for 9 months, then that part blew out and I had to switch back to my sears amp. I'm pretty sure the part in question was a PNP germanium transistor. It only had two leads, though.
ljn
Postby deltafred » 30 Nov 2014, 10:45
Clear photos would be helpful, both sides of the PCB, and especially of the part that you think is faulty.
Edit - You will probably find one of these is very similar to your schematic.
http://music-electronics-forum.com/t19128/
deltafred
Has thanked: 395 times
Have thanks: 263 times
Postby teemuk » 30 Nov 2014, 11:25
ljn wrote:I'm pretty sure the part in question was a PNP germanium transistor. It only had two leads, though.
Then it isn't a transistor.
U100... Isn't that the "Club", right? You know that Kasino amps are largely just Kustom amps in different cosmetic appearance. They recycle largely the same PC board modules. Club, according to my references, holds PC105 (preamp), PC803 (reverb & f/s control) and PC900 (power amp & +/- 8VDC regulators).
You can verify pretty easily what board numbers are of interest.
I can find a crossreference to 61088, which is a 1N3754 diode, but not a reference to 61008.
Another useful resource:
http://www.vintagekustom.com/literature/Tech/tech.html
teemuk
Have thanks: 53 times
Postby ljn » 30 Nov 2014, 17:00
Yes it is the club model. I will try to get some pics of the board when I can. As for the part in question, I lost it. It broke right off the board and pretty much fell apart. It had some kind of fluid leaking out of it prior to this. I tried, but never could find much information on this amp.
ljn
Postby ljn » 30 Nov 2014, 17:01
deltafred wrote:Clear photos would be helpful, both sides of the PCB, and especially of the part that you think is faulty.
I will try to get some pics as soon as I can.
ljn
Postby ljn » 29 May 2015, 04:04
Hello. I wanted to let all of you know the amp is working again, and I've been using it for over 20 days. I'm currently working on a tremolo pedal to use with it. Turns out some of those old solder joints had lost contact, which is what led to the failure. Thank you all very much. I do have one more question about the amp. what type of monitor does it use? there's a jack on it that's labeled " monitor". I.never knew why it was there.
For this message the author ljn has received thanks:
modman (29 May 2015, 07:37)
ljn
Postby ljn » 07 Jan 2019, 10:57
Hello everyone. It's been a long time. The amp is still working.
ljn
Postby tip142 » 07 Jan 2019, 22:08
Compliments;is possible to see some photo of the amp??
Maybe is help for other people on the forum.....
This is what people who still help ask you for solving.
You have promise photo,but i don't see......
tip142
Have thanks: 16 times
Return to Amplifiers
