Sunn Beta Bass preamp schematic
Re: Sunn Beta Bass preamp schematic
Postby guile31 » 28 Aug 2015, 20:02
Ok so, i checked the board with audio probe,the issue start on IC1 so I re-checked the converter with voltmeter and different 9v sources; the problem definitly come from it
it delivers +15/-15 but have a cyclic some kind of "leakage".
my voltmeter is just a cheap "hobby" tool, i don't know if it is enough reactive to show the real voltage drop but i can already see a leakage at each "cycle"
and the result is clearly and sadly hearable
i don't know what causes the issue so i think i'm good to test each cap of this converter
guile31
Has thanked: 24 times
Postby morain51 » 14 Sep 2015, 08:46
Finally, here is my recording of different settings on this pedal.
Quality is really bad, like my bass playing, but it's all I can share right now :oops:
https://soundcloud.com/morain51/soundclips-sunn-beta-bass
For this message the author morain51 has received thanks: 3
arcaarca (14 Sep 2015, 10:01), guile31 (14 Sep 2015, 12:15), HENK (14 Sep 2015, 10:47)
morain51
Have thanks: 23 times
Postby kyuss » 27 Feb 2016, 17:34
Hey there ! If I were to use polarized instead of non polarized caps, how should I orientate them ?
Thanks !
Xavier
kyuss
Postby grrrunge » 27 Feb 2016, 19:42
kyuss wrote:Hey there ! If I were to use polarized instead of non polarized caps, how should I orientate them ?
Thanks !
Xavier
The positive leg should connect to the side with the highest DC potential ;)
grrrunge
Has thanked: 59 times
Have thanks: 207 times
Postby kyuss » 27 Feb 2016, 20:05
Sorry but that doesn't help me at all... :)
kyuss
Postby johnk » 11 Mar 2016, 00:39
I just finished building mine and I absolutely LOVE it!
For this message the author johnk has received thanks: 4
arcaarca (11 Mar 2016, 17:13), Matamp_Classic (11 Mar 2016, 12:14), V1nce69 (08 May 2016, 10:46), Zozobra (22 Apr 2016, 13:42)
johnk
Has thanked: 31 times
Have thanks: 270 times
Postby tra » 16 Mar 2016, 17:58
If any of you have Eagle or Diptrace files for this I'll happily fabricate a board for you. I'm lazy and don't feel like doing the layout myself.
tra
Have thanks: 2 times
Postby arcaarca » 17 Mar 2016, 18:17
Hi everyone,
here are my Eagle version of the schematic, should be correct to last version... hope so ;-)
http://www.mediafire.com/download/s666l ... _Eagle.rar
cheers and good luck!
For this message the author arcaarca has received thanks:
V1nce69 (25 Apr 2016, 10:37)
arcaarca
Has thanked: 28 times
Have thanks: 10 times
Postby andregarcia57 » 18 Mar 2016, 11:55
arcaarca wrote:Hi everyone,
thanks!
andregarcia57
Have thanks: 87 times
Postby HENK » 23 Mar 2016, 14:06
Morning;
The 1N.... Diodes at the End of the last IC:
Can someone please explain,what is going on there?
I have trouble to buy them.
(Sorry for my crap English)
HENK
Has thanked: 298 times
Have thanks: 6 times
Postby grrrunge » 23 Mar 2016, 20:19
Any small signal diode should work fine there. Try 1N4148, 1N914 or similar. Those are widely available :thumbsup
grrrunge
Postby HENK » 23 Mar 2016, 22:03
:applause:
Skol to Danmark,specially to Kobnhavn :hug:
(and Greets from Haithabu...OOOOODIIIN! :wink: )
But what is the purpose of this part???
HENK
Postby grrrunge » 23 Mar 2016, 23:37
They're probably there to protect the op-amp output from odd DC voltages that might eventually be present in the superseding stage.
For this message the author grrrunge has received thanks:
HENK (24 Mar 2016, 10:31)
grrrunge
Postby Zozobra » 22 Apr 2016, 13:41
johnk wrote:I just finished building mine and I absolutely LOVE it!
[ Image ]
[ Image ]
Very nice! I'm thinking of putting together a beta bass/lead pre to feed into a small class D power amp for use as a small pedal friendly practice amp and this looks just the ticket.
Zozobra
Postby jwhtn » 06 May 2016, 17:07
[quote="johnk"]I just finished building mine and I absolutely LOVE it!
John, this looks fantastic. I know there's no lack of box finishing info on fsb, but how did you get such clean engravings? It looks CNC'd.
jwhtn
Postby bigbonedstacks » 13 May 2016, 23:18
Anyone want to hook a brother up with a labeled pcb?
bigbonedstacks
Postby rune-hammer » 22 Nov 2016, 10:50
thanks!
Was there a verified layout made available by someone here also? As far as I can see this file does not have the layout completely done.
Thanks in advance!
I started doing a beta lead thing a few years ago, but never finished it, this thread got me going again!
rune-hammer
Postby arcaarca » 01 Feb 2018, 10:45
Finally here's mine,
use tagboard layout, and a 7660 for bipolar converter (I've got +/- 17V, it works but I will put a 15V zener diode to get +/- 15V), layout is a tribute to P. Druillet.
Really good! Thanks to all FSB community!
Long live bass diyers!
Distort the world!
Arca
arcaarca
Postby HENK » 01 Feb 2018, 14:16
:horsey:
HENK
Postby DiscoVlad » 10 Sep 2018, 06:48
I've redrawn the service manual schematic for the power amp board (using the Alpha 4 PA for reference as it looks like the power sections are identical?) if anyone is interested...
This is very much unverified w.r.t. component values etc. but should be correct, and... since it's mains powered, use at your own risk. I'm not responsible if you burn your house down, or kill/injure yourself or others. :mrgreen:
I've taken the mains part out of the schematic anyway, it's just the part from the low voltage AC input forwards.
For this message the author DiscoVlad has received thanks:
HENK (10 Sep 2018, 11:31)
DiscoVlad
Have thanks: 5 times
Return to Amplifiers
Users browsing this forum: No registered users and 8 guests
