Bogner Shiva schematic?
Re: Bogner Shiva schematic?
Postby ech0es » 19 Nov 2008, 21:32
JHS wrote:
JHS wrote:Is the Diezel tone stack you're talking about the one from this thread?
No.
To me this tone stack looks more like it was copied from an Engl amp. Same issue like the stack in a Marshall 2003/4. At high volume it will do nearly nothing to the tone, a bit mid scoop, not more.
this tonestack is from the diezel VH4, we found a schematic of the tonestack and the input
ech0es
Have thanks: 6 times
Postby TragicTravisty » 11 Dec 2008, 21:20
ech0es wrote:
No.
links/pics/details?
TragicTravisty
Postby ech0es » 11 Dec 2008, 23:57
Informations about the diezel VH4, used for the conception of the DIEFET pedal from techniguitare.com
I tried to draw the tone stacks of the four channels.
Channel 1: typical Fender tone stack
Channel 2: 470pf treble cap, 22nf mid and bass caps, 39k slope resistor, 1nf cap from mid pot wiper to ground
Channel 3 and 4: 680pf treble cap, everything else like channel 2.
http://picasaweb.google.com/aliasbarrylyndon/Diezel#
http://www.megaupload.com/?d=9RZ8JEEK
ech0es
Postby chromaticdeth87 » 12 Dec 2008, 20:49
holy crap! that had to suck staking all those turrets
chromaticdeth87
Postby TragicTravisty » 12 Dec 2008, 22:17
worked this out on a tonestack calculater, the result for channel two is lots of high filtering, slight cut at 1khz (less than a fender), and a big bass boost at around 80 hz. thats without factoring in the cap from mid control to ground, and channel three has slightly more mids, and treble.
TragicTravisty
Postby paulrodga » 29 Jan 2009, 00:36
More about the Shiva schematic? What is the correct one?
paulrodga
Postby erigm » 19 Feb 2009, 05:36
chromaticdeth87 wrote:holy crap! that had to suck staking all those turrets
What turrets? I didn't see any. Did I miss something?
erigm
erigm
Postby luchomack » 10 Oct 2017, 14:41
here...
For this message the author luchomack has received thanks: 2
blackbunny (11 Oct 2017, 01:42), roseblood11 (10 Oct 2017, 19:26)
luchomack
Have thanks: 4 times
Postby luchomack » 10 Oct 2017, 14:44
other. i need the shiva power supply schematic...
luchomack
Postby luchomack » 10 Oct 2017, 15:11
preamp
blackbunny (11 Oct 2017, 01:43), roseblood11 (10 Oct 2017, 19:26)
luchomack
Postby Heph333 » 04 Jun 2018, 23:21
Sorry to resurrect an ancient thread, but what is up with that orphaned V1A tube?
Heph333
Postby luchomack » 03 Jan 2019, 02:24
v1a dont to use, its for other versions with circuit reverbs and others...
luchomack
Previous
Return to Amplifiers
Users browsing this forum: Google [Bot] and 1 guest
