peavey MX vtx series footswitch
Postby ksenanekro » 04 Jul 2015, 11:57
hi mates.
i have this amp
http://assets.peavey.com/literature/man ... 343009.pdf
http://www.kijiji.ca/v-other-musical-in ... 1040475576
http://www.cavallimusica.com/chitarre/c ... eries.html
unfortunately i don't have the footswitch/remote switch, which is the only way to go from lead to clean(!)
so....
i've searched everywhere and i can find the schem for that footswitch
it has a 4 pin din unlike most peavey amps that have a 5 to 7 pin dins
is there anyone that could help??
thanks
Savvas
ksenanekro
Has thanked: 13 times
Have thanks: 35 times
Re: peavey MX vtx series footswitch
Postby karul » 04 Jul 2015, 12:20
According to the schematic, the pins are
1 - REVERB GND
2 - REVERB
3 - CHANNEL GND
4 - CHANNEL
pins 1 and 2 are for the REVERB ON/OFF
pins 3 and 4 are for CHANNEL SWITCHING
For this message the author karul has received thanks:
ksenanekro (04 Jul 2015, 12:55)
karul
Has thanked: 259 times
Have thanks: 160 times
Postby ksenanekro » 04 Jul 2015, 12:58
huge thanks mate!
that was superfast!
i've already tried this by shorting the tips with aligator clips and it works!!!
thanks again!
ksenanekro
Postby marc036 » 12 Jul 2019, 10:05
Hello,
I just made a plug in which I connected 1 + 2 & 3 + 4
There's no channel indicator as far as I know
Reverb is no longer working, if I take the plug out reverb is working again.
So got those pins right.
In what mode does the amp start with no plug clean channel / reverb on ?
Please advise.
Marc
marc036
Postby karul » 12 Jul 2019, 14:10
marc036 wrote:Hello,
Please advise.
Marc
what kind of switches you're using? latching or non-latching (momentary)? you need two separate latching switches. one for the reverb, one for channel switching. if you want state indicator, you'll need battery or power supply and some LED's and proper resistors.
karul
Postby marc036 » 12 Jul 2019, 16:02
I am not using any switches I just connected the pins.
What I want is to run this amp with clean channel and reverb, that's all.
I have a pedal steel and not a guitar, that's why.
Cheers
Marc
marc036
Postby karul » 12 Jul 2019, 19:24
I'm not very familiar with this amp. I recommend you to carefully read the manual.
It seems that the to use the Normal (clean) channel, you should connect 3 & 4. Try to leave 1 & 2 disconnected so the Reverb will be ON, all the time.
User manual for MX VTX Series:
https://www.manualslib.com/manual/62047 ... eries.html
karul
Return to Amplifiers
Users browsing this forum: Exabot [Bot] and 2 guests
