Pretty good sounding amp based on the demos I found from youtube.
Found just one gut shot and not very good quality, but here is something I came up with. Signal cap values are just quessed from the size. Some resistor color codes are hard to read, but the basic topology should be like I've drawn it. Feel free to comment and contribute! I only drew the power string and left the rectifier and PT off.
Dr. Z Therapy
- Dingleberry
- Dingleberry
Just realized that the two first filter caps might not be 100uf, but probably a bit smaller. Maybe 68uf? 100uf would probably stress the GZ34 a bit too much.
Simplify before you amplify.
