19" tube amps, patch panels and shielding.
- Cub
I've decided to split up my big heavy rack and divide the units into smaller cases with a more manageable weight. The downside is that I have to connect more than just the speakers, MIDI cable and a power cord whenever I play somewhere and that's where I could use some advice from you.
Panels like these would make for a very elegant solution and it shouldn't take too long to connect everything.
But it's the view from the back that makes me scratch my head. Bits of exposed, unshielded wire only centimeters away from glowing tubes. Isn't that going to introduce noise?
Am I worrying over nothing here, or would it be better if forget about the Neutrik D-size panel connectors I went with these shielded jacks from Switchcraft instead?
- Pruttelherrie
I think you worry too much
I assume 'glowing tubes' refers to audio tubes of your amps? In that case there's only worrying about 6.3V AC filament supply wires, which are most of the time twisted and *inside* the cases anyway!
Just my €0.02
Just my €0.02
- phatt
NO,, not if the circuit(s) is made well.Cub wrote: Isn't that going to introduce noise?
IF you have a crap Ground plane wiring and earth loop issues then it may present some extra headaches.
Phil.
- Cub
Thanks lads!
The preamp and power amp together have a dozen of tubes sticking out the back already, but it's not just that had me worried. There's wires with power, MIDI, a power supply for a couple of stompboxes, antennas for the wireless receiver and transmitter for the in-ear-monitor.
With all of that going on, I figured I really needed to shield off everything. But if you say it's all right, I trust I can go ahead and make some neat looking panels with those posh Neutrik connectors.
- Pruttelherrie
You could always bend a bit of sheetmetal around the back of that panel should it turn out to pose problems in your case, but I don't expect that to be necessary.
