Cornford MK50II rebuild
I build the MK50 II last year. The Amp is working fine.
Some people asked me for the layout and the verification fot it, but I'm the only one who build the monster yet. So I'm looking for some volunteers to check my layout.
Cheers, lhd3000
Cheers, lhd3000
- Cornford MK50H II Layout Ready to Build V5.0.pdf
- (416.71 KiB) Downloaded 191 times
- okgb
The phase invertor looks like it has a cap going from plate to plate [ seems purposeful , is that correct ? ]
I haven't looked heard at it [ or heard a real Cornford in person ] looks to be a fender clean and marshall like o/d ?
can you describe how it sounds? sort of ? thanks
The cap between the plates is completely correct.
As you have already said, the clean channel sounds more like a fender, the OD channel is more soldano, but with a good bassrange, also endless sustain.
- gehaeuse_oben1.pdf
- (75.38 KiB) Downloaded 132 times
- gehaeuseobenunten.pdf
- (74.03 KiB) Downloaded 123 times
fs = footswitch
they're going to a 5 pole soocket (midi socket) http://www.musikding.de/bilder/produkte ... -polig.jpg
okgb wrote:The phase invertor looks like it has a cap going from plate to plate [ seems purposeful , is that correct ? ]
The cap in the pi is to stabilise the NFB loop. There are better ways to do it but this is the most common and it's found in nearly all Marshall inspired circuits.
PT
W1 -> 320V / 270mA
W2-> 50V / 50mA
W3-> 6,3V / 6A w. CT
W4 -> 12V / 2A w. CT
It's custom build, payed s. about 100 €.
OT
http://www.tube-town.net/ttstore/Transf ... :5994.html
W1 -> 320V / 270mA
W2-> 50V / 50mA
OT
