Blackstar Fly 3 schematic request
Postby bancika » 10 Apr 2017, 10:01
anyone has schematic of this little amp? I own it and am just curious to see what they did.
It's all SMD, so it's a bit of a pain to reverse engineer. Would maybe consider modding the tone stack if it's possible to do without too much SMD work, but it's unlikely.
Tnx,
Bancika
bancika
Has thanked: 16 times
Have thanks: 81 times
Re: Blackstar Fly 3 schematic request
Postby bancika » 25 Apr 2017, 14:30
Didn't find schematic but I was able to make this cool little amp much cooler. It's good sounding, although a bit dark and for metal it lacks gain. It's possible to fix using a booster, but it kind of defeats the purpose of a super-portable mini amp.
So I built a small JFET booster, found a trace to cut so I can inject it in the circuit right after the input jack and added a DPDT switch to bypass it. It turned it into a 4 channel amp. Booster adds at least 6-9dB and pushes the amp into heavy distortion but also helps bring out the highs significantly. Loving this little amp even more now :)
For this message the author bancika has received thanks: 2
apollomusicservice (25 Apr 2017, 16:40), peterc (26 Apr 2017, 06:39)
bancika
Return to Amplifiers
Users browsing this forum: Steeler [Crawler] and 1 guest
