Tube preamp almost ready
Postby Aharon » 10 Apr 2017, 14:28
this is the work so far,tested thee power supplies And they work fine.
Found a pcb on line and took a screen pic of it and re did it with my PCB prog,debuged it ,found what I think is a mistake and etched it ,stuffed the sucker and found the rest of the parts in my "junk" box.I'll update when it's finished.[attachment=0]Untitled.jpg
Aharon
Has thanked: 24 times
Have thanks: 8 times
Re: Tube preamp almost ready
Postby Aharon » 10 Apr 2017, 15:16
Here's the link to the artwork,sorry I no longer have my artwork for it but if you do the same I did you can make your own easy,to me there's a mistake in the tone stack but check it ,hope I'm right cause I've corrected it on mine.
https://www.google.com.uy/search?q=hotb ... GyaTu6rbtM:
Aharon
Aharon
Return to Amplifiers
Users browsing this forum: No registered users and 9 guests
