Help with PT wiring
Help with PT wiring
Postby spoontex » 28 Sep 2017, 13:20
Hello,
I need some help for wiring a power transformer. This one:
http://www.classictone.net/40-18097.pdf
If I have 230V I have to solder the WHT and BLK/WHT together, and the BLK and GRY are the power input.
But now the question. What is the SS ORN Cable?? and the RED/YEL CT and GRN/YEL goes to ground?
Thanks!!
spoontex
Re: Help with PT wiring
Postby alexradium » 28 Sep 2017, 13:54
ss is the shield,goes to ground.
red yellow goes to same ground of the main filter cap.
green yellow usually goes to ground,but can also be elevated 50/70 volts to prevent excessive hum and preserve cathode follower tubes.
alexradium
Has thanked: 51 times
Have thanks: 53 times
Postby spoontex » 28 Sep 2017, 15:13
Many thanks!! If I understand correctly, if you don't have a CT transformer, is necessary install two 200r resistors into the pilot light and ground. But this transformer have CT. If I ground, is necessary install the two resistors??
Thanks.
P.D.: the original layout shows, green yellow and red yellow to ground.
https://www.google.es/search?q=bassman+ ... Ry3a9LrI2M:
spoontex
Postby alexradium » 28 Sep 2017, 18:44
spoontex wrote:Many thanks!! If I understand correctly, if you don't have a CT transformer, is necessary install two 200r resistors into the pilot light and ground. But this transformer have CT. If I ground, is necessary install the two resistors??
no, its one or the other.
alexradium
Postby spoontex » 28 Sep 2017, 20:10
Thanks. It's a bassman aa864 that works with 120VAC. I can replace with the classic tone transformer without any issues no?
spoontex
Return to Amplifiers
Users browsing this forum: No registered users and 6 guests
