Krank Rev Jr Pro 50W
Postby grrrunge » 09 Feb 2018, 01:41
I Haven't had much action around these parts lately, and the channel switching in this bad boy started acting up, so let's get the trace show running.
I haven't seen schematics for these elsewhere :horsey:
First up: Board A - the preamp board.
Board B contains the power amp and tube driven effects loop. I'll take photos of it as soon as I finish tracing board A.
For this message the author grrrunge has received thanks:
J0K3RX (09 Feb 2018, 04:36)
grrrunge
Has thanked: 59 times
Have thanks: 207 times
Re: Krank Rev Jr Pro 50W
Postby Optical » 09 Feb 2018, 06:01
I think the Rev Jr is the krankenstein with a fixed tone stack and a BMP tone control after that?
Here's a schem that might be a good place to start comparing
For this message the author Optical has received thanks:
grrrunge (11 Feb 2018, 17:57)
Optical
Has thanked: 10 times
Have thanks: 13 times
Postby grrrunge » 11 Feb 2018, 18:02
Looks like they have quite a bit in common, though it seems this PCB accomodates circuitry to switch between a solid state or tube buffered effects loop instead of multiple master volumes ;)
Here's the work in progress. It's linking to my dropbox, so this will always be the latest revision.
https://www.dropbox.com/s/6597c8n31ii0zr3/krank_rev_pro_jr_preamp.png?dl=0
grrrunge
Postby grrrunge » 16 Feb 2018, 09:12
The preamp board is pretty much done - this was a messy bugger to trace out. When comparing it to the Mesa and Soldano amps I've otherwise worked on, even the japanese SP-77 knockoff sports a nicer PCB layout :lol:
grrrunge
Postby grrrunge » 21 Feb 2018, 12:58
For this message the author grrrunge has received thanks: 2
FiveseveN (21 Feb 2018, 20:57), snofla1900 (21 Feb 2018, 13:44)
grrrunge
Postby Optical » 21 Feb 2018, 23:14
Thanks - very tidy work
Optical
Return to Amplifiers
