Dr.Z For All
Re: Dr.Z For All
Postby madditch » 11 May 2009, 22:21
The 18 watt transformers from http://www.mojomusicalsupply.com/ will work.
madditch
Re: Dr.Z For All
Postby SPeter » 12 May 2009, 00:17
SPeter
Have thanks: 75 times
Re: Dr.Z For All
Postby ansil » 16 Sep 2009, 09:12
tried to download this it says file is private could someone email it to me or provide a link that isn't private???
ansil
Have thanks: 12 times
Re: Dr.Z For All
Postby SPeter » 16 Sep 2009, 16:43
What did you try to download?
SPeter
Re: Dr.Z For All
Postby invalidcd » 16 Sep 2009, 17:50
ansil wrote:tried to download this it says file is private could someone email it to me or provide a link that isn't private???
Try now i must of made it private by accident, should be good to go.
invalidcd
Have thanks: 13 times
Re: Dr.Z For All
Postby cortezthekiller » 17 Sep 2009, 00:35
I had built an amp based on the Phoenix design a while back and it's awesome.
I used an old piece of staircase for the cabinet of it (used as a head).
cortezthekiller
Has thanked: 22 times
Have thanks: 52 times
Re: Dr.Z For All
Postby ansil » 17 Sep 2009, 06:30
thanks for unlocking it for me i appreciate it. soon as i get my harddrives back online i will dig through to see what i can contribute :)
ansil
Re: Dr.Z For All
Postby jaxx » 21 Sep 2009, 20:29
take this gift guis.
:applause:
jaxx
Have thanks: 2 times
Re: Dr.Z For All
Postby SPeter » 12 Oct 2009, 21:14
Hi all, does anyone have the schematic/more information about Prescription ES Model?
Sounds AMAZING!
Listen the 4-th clip!
http://www.drzamps.com/rxes.html
Thanks in advance!
Peter
SPeter
Re: Dr.Z For All
Postby BigMoose » 25 Nov 2009, 01:38
Is the Mini Z running like 380 V B+, 375 V to the EL84 screen grid and ~ 345 V to the preamp sections?
BigMoose
Re: Dr.Z For All
Postby plexilover » 08 Dec 2009, 11:43
anything bout the attenuator at the mini z?
thanks for pictures and schemos!
regards
plexilover
Re: Dr.Z For All
Postby jabsalt » 12 Dec 2009, 04:16
can someone please give me the specs on the Mazerati GT PT, OT and choke. thanks
jabsalt
Re: Dr.Z For All
Postby jaxx » 16 Dec 2009, 00:28
for the mini z i dont think voltages are right.
380V on plate and 370 on grid is too much.
for the maz gt specs may be
pt
270-0-270 200mA
ot
4k primary
choke
10H 200mA i think is a good choice
jaxx
Re: Dr.Z For All
Postby jabsalt » 16 Dec 2009, 05:50
jaxx wrote:for the mini z i dont think voltages are right.
pt
270-0-270 200mA
ot
4k primary
choke
Awesome, thanks
jabsalt
Dr. Z Maz Redrawn
Postby jayster2 » 23 Dec 2009, 00:36
If incorrect please advise and I'll update it. Thanks
jayster2
Re: Dr.Z For All
Postby jaxx » 23 Dec 2009, 15:51
the scheme you posted, maz18jr reverb, is not properly correct, there are some mods to do.
this is the maz 18 NR scheme that i draw from some photos.
transformers specs and power section i think are pretty close to the original, for the rest is totally correct.
if anyone have some photos or more detailed schemes for power section or transformers specs, post it!!! :horsey:
For this message the author jaxx has received thanks:
Manfred (13 Jan 2013, 23:23)
jaxx
Re: Dr.Z For All
Postby jayster2 » 23 Dec 2009, 17:06
Jaxx, Thanks! I'll update
jayster2
Re: Dr.Z For All
Postby Seljetnoma » 24 Dec 2009, 14:50
Has anyone seen the inside of the new Dr.Z jaz 20/40 amps?
The preamp supposed to be very similar to the maz preamp, but with a few slightly different values here and there.
One thing I'm sure of is that it has a 100k slope resistor and a 120pf treble cap in the tone stack.
There are a few pics of the jaz guts on the website of http://www.proguitar.de , check out the amps section.
Also the orange drop coupling caps seem to me like 715p series instead of the usual 418 dr.z branded caps, can anyone confirm this?
Anyways, thanks a lot and Merry Christmas.
Frank
Seljetnoma
Re: Dr.Z For All
Postby SPeter » 27 Dec 2009, 23:17
Thanks jaxx!
:applause:
:D
SPeter
Difference between Mazerati & Mazerati GT
Postby DanMask » 05 Jan 2010, 06:06
Hi folks. Just finished building a Mini Z. Attached picture for you guys. Almost finished my Carmin Ghia. Since the Carmin Ghia and a Mazerati have the same circuit, I am collecting parts for the later to build as well. The differences I see is the GT has the main filter caps on board (no big deal), a choke (curious if anyone knows what value it is or a close idea), what the 10w resister hanging to the left of the circuit board is & what it is attached to, there is a small mica cap between two legs of the two .022 sprague 715p caps (cant tell what value it is). Any help here and anything I am not seeing?
Dan
Sumter, SC
DanMask
Return to Amplifiers
Users browsing this forum: No registered users and 7 guests
