Page 1 of 6
Dr.Z For All
Posted: 27 Jul 2008, 05:00
by invalidcd
I have drawn up schematics for Mazerati-GT, Stangray ,and Mini Z , so i decided to make a zip-file of all the known Z layouts and schematics.
Enjoy
http://www.mediafire.com/?en4cmeen41o
Re: Dr.Z For All
Posted: 27 Jul 2008, 05:45
by drumslinger
SWEET!
Re: Dr.Z For All
Posted: 27 Jul 2008, 13:09
by RnFR
now thats just awesome.
Re: Dr.Z For All
Posted: 27 Jul 2008, 13:33
by gnognofasciani
Re: Dr.Z For All
Posted: 27 Jul 2008, 21:49
by briggs
RnFR wrote:now thats just awesome.
+1
Re: Dr.Z For All
Posted: 29 Jul 2008, 16:54
by guilds100
Thannk you. Thank you.
Re: Dr.Z For All
Posted: 30 Jul 2008, 08:15
by briggs
I really like the look of the Carmen Ghai's tone control setup. I think I might give it a try
Re: Dr.Z For All
Posted: 30 Jul 2008, 15:48
by AL
I can't seem to download these. It says I need a supported browser. Do I need to get an account for this?
And thank you for the work on the schems.
*Edit* Got it downloaded. Thanks
AL
Re: Dr.Z For All
Posted: 02 Aug 2008, 17:21
by klingo
briggs wrote:I really like the look of the Carmen Ghai's tone control setup. I think I might give it a try
this tone control is great but you must know it's a mid scooper and not a low loss one.
personnaly i like to insert a 47KA pot/trim between the 10nf and ground that let me dial the amount of mid-scoop/gain-drop. of course with this pot/trim maxed the tone control is less effective but restored mids sound better for distortion IMHO.
last thing, if it work backward your wiring is correct
Re: Dr.Z For All
Posted: 04 Aug 2008, 17:17
by fluzo
Thank you.
Does anybody know the Route 66 transformer specs? OT primary impedance in particular.
Re: Dr.Z For All
Posted: 04 Aug 2008, 17:52
by invalidcd
fluzo wrote:Thank you.
I think its a 4k ultra linear.
Re: Dr.Z For All
Posted: 05 Aug 2008, 06:52
by islandamp
Has anyone drawn up a schematic for the Prescription jr. yet?
Re: Dr.Z For All
Posted: 05 Aug 2008, 11:07
by fluzo
Thanks. Why ultralinear? On the schematic it looks like normal push-pull operation...
invalidcd wrote:fluzo wrote:Thank you.
Re: Dr.Z For All
Posted: 05 Aug 2008, 18:06
by klingo
fluzo wrote:Thanks. Why ultralinear? On the schematic it looks like normal push-pull operation...
no screen choke or resistor supply, KT66 screens are connected to a tap at the output transformer (43%). so it is ultralinear. the MOV/genalex datasheet is showing a 8K OT (with higher voltage) . i don't know what the good Dr use in it, but 6K6 and 8K OT seem common with KT66.
http://www.drtube.com/datasheets/kt66-mov77.pdf
Re: Dr.Z For All
Posted: 06 Aug 2008, 18:09
by fluzo
Thank you klingo
Re: Dr.Z For All
Posted: 11 Aug 2008, 17:15
by chicago_mike
I havent seen a Route 66 schematic yet, but I keep thinking its gotta be an old mullard circuit.
You look in the mullard amp circuit book, theres a Ef86, and 2 kt66 amp that just seems to scream the route 66 to me...
I could just be really goofy too.
Re: Dr.Z For All
Posted: 12 Aug 2008, 20:22
by klingo
nothing new.
OK rt66 tone stack is cool.
Re: Dr.Z For All
Posted: 29 Aug 2008, 17:21
by shicky
Hi, I am trying to build mini z for my first tube amp project.
I have a few questions.
1. It was impossible for me to get 40uF 450V and 20uF 450V capacitors used in Rectifier (Bridge?) section.
I was able to get 47uF 450V and 22uF 450V.
Values didn't really make a huge difference in PSU Designer graph but I would like to make sure if I can use those.
2. What should I use for Rectifier Diodes, 1N4001?
3. What would be the fuse size? is 1A sufficient?
I would really appreciate your help.
- shicky -
Re: Dr.Z For All
Posted: 29 Aug 2008, 17:31
by tunghaichuan
shicky wrote:Hi, I am trying to build mini z for my first tube amp project.
They will be fine. Caps are usually 20% unless marked differently, so a few uF won't make that much difference, if any.
I'd use 1N4007s, rated for 1A, 1000V.
[/quote]
Not sure, I usually use 2A fuses in builds of this power level.
tung
Re: Dr.Z For All
Posted: 11 Sep 2008, 16:24
by fluzo
I have tried the Route 66 BASS + TREBLE eq in my EF86 amp and it doesn't suck tone.
Any ideas on how to make the treble control more "trebley"? The bass pot works fine but the treble pot is a bit dark to my ears...
Thanks for your help.
