Jumpering channels to get dirt on your Fender-style amp
Postby Desdog » 28 Mar 2018, 21:08
Link
I'm almost sure the double inputs were not designed to do this, but it's a great mod. In fact, it's just coupling the inputs, but with some resistors? Is there then 130k between the two channels in a Deluxe?
I'm just trying to squeeze some distortion from this this dual input PA tube amp with 2xEL34:
I would like to wire this up with a switch, maybe even make V1b a dedicated distortion path. I think I tried jumpering the inputs, that didn't do much. But will test again tomorrow...
Desdog
Has thanked: 62 times
Have thanks: 15 times
Return to Amplifiers
Users browsing this forum: Steeler [Crawler] and 2 guests
