my amp tone stack problem
Postby ballfire » 14 Apr 2018, 05:54
good day
i traced my amp tonestack and i found this check below pic..when i turned down the all knobs to zero the output signal of my amp lost i mean no output at the speaker..is there a problem in the components of this tone stack?? when i turn up the knobs again the signal came back..??sorry my amp lots of problem its a cheap amp i think from elswhere i dont know..
any advice or opinion or solution??
thanks
ballfire
Has thanked: 28 times
Re: my amp tone stack problem
Postby phatt » 14 Apr 2018, 12:27
That is a standard tone stack and that is how they work,,i.e Normal operation.
Nothing wrong with the circuit. thousands of old fenders do that. 8)
Phil
phatt
Have thanks: 264 times
Postby lead2203 » 15 Apr 2018, 23:58
ballfire wrote:good day
thanks
That's more like a Fender tone stack, although different values. Look at the Marshall tone stack. It's mid control is wired different so that it doesn't cut the signal when everything is set to 0
lead2203
Have thanks: 9 times
Postby ballfire » 16 Apr 2018, 05:25
phatt wrote:That is a standard tone stack and that is how they work,,i.e Normal operation.
Phil
good day..
now i know now my cheap guitar amplifier is like on fenders..i will just leave the way its tone stack
ballfire
Return to Amplifiers
Users browsing this forum: Fat Bob and 2 guests
