Danelectro Honey Tone Amp Doesn't Work
Postby mwelch55 » 02 May 2018, 17:06
I was using my Danelectro Honey Tone amp with an audio signal probe I built to troubleshoot audio circuits. It worked great until I used it to probe a tube preamp circuit. Now there is no output. I think I blew the op amp (TL072) because the signal is too high in a tube preamp. I will replace the op amp as soon as I can get one.
What would be the best way to limit the input signal to this little amp? Would zeners on the input be a good way to limit the input signal?
Mike
mwelch55
Re: Danelectro Honey Tone Amp Doesn't Work
Postby mwelch55 » 02 May 2018, 22:49
This is what I was talking about. Would the zeners on the input provide protection for the op amp? If so, what values would you recommend?
mwelch55
Return to Amplifiers
Users browsing this forum: Siddh and 4 guests
